Old 18-06-2006, 06:09 PM   #1
lone46
Default Ford Telstar Gear box problem
I have a 1991 ford telstar. I just change the 2.0 DOHC Automatic engine, it is Ford engine too. That engine has 4 gear, i don't know why it is just can run until third gear, and the fourth gear almost cannot work. Anyone face this problem before? it is make me quite trouble now...
lone46 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2006, 03:38 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
make sure all the auto wires are connected
reset the ECU
oil levels perfect
if no better the overdrive or end clutch has failed
take the end clutch cover off and inspect the end clutch
My car goes Brumm Brumm
Old 19-06-2006, 07:13 AM   #3
dirty hands
Over Thinker
if you changed the auto gearbox over and the engine as well
the ecu to a different gearbox will be different ?
you need the new gearbox ecu and all wired in to work it
