Old 07-06-2006, 07:49 PM   #1
39ClevoUte
39ClevoUte's Avatar
Default Mazda 1.8 DOHC in Place of Capri (Laser) 1.6 DOHC
Hi all
Wifes 1.6 has been cooked and thought maybe a later model 98 1.8 might fit into the 93. Anyone done this??? If so what are the tricky bits.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 08:43 PM   #2
galaxy xr8
Giddy up.
galaxy xr8's Avatar
They are basically the same motor just bigger displacement, I would assume it would be a straight conversion.
Old 07-06-2006, 11:24 PM   #3
VippiN
What a performer!
VippiN's Avatar
Brackets are generally the same, wiring is the main problem here.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2006, 11:26 PM   #4
39ClevoUte
39ClevoUte's Avatar
Vippin mines already a DOHC, is the engine different or is it just displacement??
Old 07-06-2006, 11:30 PM   #5
VippiN
What a performer!
VippiN's Avatar
Yeah I realised that after re-reading your post and edited..
The only real dramas I had was the drivers side engine mount (which you already possess so.. easy) and the wiring. The plenum and surrounding is a bit larger and basically gives little no room between it and the firewall.. otherwise is fine.
Old 08-06-2006, 12:23 PM   #6
39ClevoUte
39ClevoUte's Avatar
Was it worth it?
Old 08-06-2006, 05:46 PM   #7
VippiN
What a performer!
VippiN's Avatar
Power wise? Not really worth the money ($1600 all told, inc heavy duty clutch and all new bits) I believe if I had my chance over I would've bought the snailed version (BPT) instead. Though being in SA i'm playing it smart and avoiding regency.
When dyno day comes next month i'll let you know for sure. I got 42.3fwkw with the 1.6 EFI (B6) so we'll see what the BP pulls.
