Old 04-06-2006, 08:39 PM   #1
iosa
Laser Fan
Default 85 KB Laser - Handbrake Cable Replacement?
Hi,
What would you be looking at to get a handbrake cable replaced on the 85 KB Laser? My dad managed to burn the cable when blowing off a stripped bolt on the exhaust line, so the handbrake cable seizes when pulled, the only way to let it down is to manually pull the line from the back wheels. Would it be easier to scab one from the wreckers and replace it myself?
Cheers,
Nathan Manzi
iosa is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 08:53 PM   #2
Holbrookau
OPT 20
Holbrookau's Avatar
If you can still get new ones (unlikely) they would be fairly expensive - the wreckers would definatly be the go. Sounds like your dad is a handy-type person so no point giving a mechanic your cash for something you can do yourselves.
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 08:53 PM   #3
VippiN
What a performer!
VippiN's Avatar
Yep, Holbrookau knows the score.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 09:54 PM   #4
iosa
Laser Fan
Cheers guys, another one, the idle jet is blocked on the bastard, I've tried everything short of taking the carbie out and unblocking it with some compressed air, any ideas on easier solutions?
Cheers once more,
Nathan
Old 05-06-2006, 09:51 AM   #5
dirty hands
Over Thinker
dirty hands's Avatar
its a common fault with the carby take off the incoming fuel line to the carby and blow compressed air (in short bursts) from there
if that doesnt work then you have to take the top off the carby
with the hand brake make sure you buy the outer sleeves and inner cables
not a hard job just a pain
I wish vippen etc had a scanner and a repair manual to post up some (how to do )pics for the lasers
My car goes Brumm Brumm
