Old 21-03-2006, 11:38 AM   #1
act2617
Thumbs down Nice one uncle Sam
Depleted uranium results from the enriching of natural uranium for use in nuclear reactors. Natural uranium is a slightly radioactive metal that is present in most rocks and soils as well as in many rivers and sea water. Natural uranium consists primarily of a mixture of two isotopes (forms) of uranium, Uranium-235 (U235) and Uranium-238 (U238), in the proportion of about 0.7 and 99.3 percent, respectively. Nuclear reactors require U235 to produce energy, therefore, the natural uranium has to be enriched to obtain the isotope U235 by removing a large part of the U238. Uranium-238 becomes DU, which is 0.7 times as radioactive as natural uranium. . Since DU has a half-life of 4.5 billion years, there is very little decay of those DU materials. When manufactured as 30mm rounds, each DU projectile contains approximately 4,650 grains [0.66 pounds (lbs)] of extruded DU, alloyed with 0.75 weight percent titanium. The projectile is encased in a 0.8 mm-thick aluminum shell as the final DU round.
During Operation DESERT STORM the Air Force fired 30mm Armor Piercing Incendiary (API) munitions using a depleted uranium [DU] penetrator slug from the GAU-8 Gatling gun mounted on the A-10 Aircraft. The 148 A-10s that deployed to Saudi Arabia flew 8,077 combat sorties. The Air Force fired a total of 783,514 rounds of 30mm API in the Gulf War. Since each round contains approximately 0.66 pounds of DU, the Air Force expended a total of 259 tons of DU in the Gulf. The armor-piercing capability of the DU projectiles fired from A/OA-10s proved exceptionally effective in countering threats from the Iraqi tanks so that a successful ground offensive could then be achieved.
At times 30mm DU rounds misfire in the A-10?s GAU-8 cannon. These "hangfires" have to be cleared and removed from the gun barrel, potentially exposing ground crews to airborne DU. Technical data available to maitenance crews does not provide an accurate means for determining the status of rounds in an unsafe/jammed gun, and revisions are in progress.
act2617 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 11:56 AM   #2
Psycho Chicken
Psycho Chicken's Avatar
Wait I don't see your point?
It's not nice to hurt people in a war?
And hangfires in a GAU-8 don't need to be cleared at all. An unfired round will eject like an empty shell.
Old 21-03-2006, 11:58 AM   #3
Casper
Contributing Member
Casper's Avatar
ok, so we should tell them to use "nurf" guns? :
Older, wiser, poorer.
Old 21-03-2006, 11:59 AM   #4
Polyal
The 'Stihl' Man
Polyal's Avatar
And.........
useless post I know...but seriously............
  • 1973 ZF Ford Fairlane
Old 21-03-2006, 12:04 PM   #5
flappist
Wars are dangerous m'kay.......
Old 21-03-2006, 12:05 PM   #6
Sourbastard
Contributing Member
Sourbastard's Avatar
weapons of spongey destruction
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 21-03-2006, 12:08 PM   #7
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Australian cars and trucks dumped something like 65 million tonnes of greenhouse gasses into the atmosphere during 2002... monsters...
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 12:15 PM   #8
Gunns
Gunns's Avatar
"War its fantastic!"
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 12:15 PM   #9
fiery
fiery's Avatar
All you all trying to imply you actually read that whole first post?
Seriously?????????
Originally Posted by MNM96
Quit wingeing, drink more and grow a Butt! Its un Australian not to be the correct size to fit the seat of a Falcon!
fiery is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 12:22 PM   #10
Mack 6
SUMP PLUG
Mack 6's Avatar
Field Artillery in both the gulf wars used depleted uranium shells at well.
A lot the the cases of Gulf War syndorme have been linked (I use that term loosley) to the exposure of troops to depleted uranium.Not just st the firing points, but also at the impact sites of ammunition.
Did you know that it is against the Geneva convention to have a rusty bayonet becasue if you stab someone and they don't die, they could get an infection and suffer more than if you had stabbed them again and they had died.
Give me the good old days of Hueys, Ride of the Valkyries, and surfing while under attack.
Mack 6 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 12:26 PM   #11
4.9 EF Futura
Dont you think it's a little risky for R&R sir?
Old 21-03-2006, 12:28 PM   #12
Sourbastard
Contributing Member
You love the smell of napalm in the morning, and the taste of BBQ wombat in the evening.
Old 21-03-2006, 12:28 PM   #13
Gunns
Gunns's Avatar
Did you know that it is against the Geneva convention to have hollow tip rounds, so instead of passing stright through someone it just gets stuck in. But bubble tipped rounds fine to use
Old 21-03-2006, 12:28 PM   #14
flappist
Seriously?????????
Kerri, it is a WAR ZONE. Workplace, health & safety officers are a bit thin on the ground. Yes DU is bad for you but not as bad for you as being shot because you did not stop the other guys first.
There are many many instances of soldiers being exposed to bad things in history. Remember agent orange?
This doesn't mean it is right to expose soldiers to bad things it is just that in war there are no silver medals.......
Old 21-03-2006, 12:35 PM   #15
fiery
fiery's Avatar
yeah ok...... Tony I have gone back since your post (yes you made me feel quite guilty for not doing so in the first place)
I thank you for that :
Old 21-03-2006, 12:36 PM   #16
flappist
Actually it was the Hague convention of 1874 http://www.mtsu.edu/~baustin/hague2.html , the Geneva convention of 1949 was mostly about treatment of prisoners of war.
Old 21-03-2006, 12:37 PM   #17
Gunns
Gunns's Avatar
Well there you go. I learn something new everyday
Old 21-03-2006, 12:39 PM   #18
flappist
Apocalypse Now was not a documentary?
Old 21-03-2006, 12:40 PM   #19
flappist
I only know this beacuse I said exactly the same thing once and had a nice Major explain it to me..........
Old 21-03-2006, 12:42 PM   #20
Des
V8 Rock'n'Roll....
Des's Avatar
Location: You got me Rootin' like a Hog, Barkin' like a Dog, Climbing trees and Jumping logs....
The effects of DU have been common knowledge in certain circles for a long time, not just for combatants, but also for the residents. The UN has had investigations into it's use, though even if they ban it, the US will still use it as it the most effective anti-amour round available. Banning chemical agents hasn't stopped the US from having some of the largest plants around. Though the US only use them for research and development of cures, and the Japs use whale meat for scientific purposes. :evil_laug
1 owner 03 BA XR8 Manual Sedan
208.8 rwkw stock, update soon
20x8.5 fr 20x10 rr
Rumble thanks to:
Sureflo Exhaust - Stainless Cat's & 3.5in single catback system
"Tell 'em the guy with the Blue Mohawk sent Ya"
Des is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 12:44 PM   #21
Mack 6
SUMP PLUG
Mack 6's Avatar
There are no such things as nice Majors, just ones who haven't realised that you are a Non-Commissioned Officer yet.(and you haven't saluted or even called them sir yet LOL)
Old 21-03-2006, 12:52 PM   #22
Psycho Chicken
Not to mention all the nasty stuff the Iraqis had been using in the decade before Gulf War mk 1.
There's a lot of people claiming DU is responsible for Gulf War Syndrome, though it really could be anything from oil field fires to the "Anthrax Vaccine" they were giving out.
Charlie don't surf!
Old 21-03-2006, 01:09 PM   #23
Mack 6
SUMP PLUG
Mack 6's Avatar
Or the "Kane Madenss" anthrax vaccine for any of those people that have seen "Evolution" with david duchovney.
Post Traumatic Stress Disorder is another problem. I've seen evidence of it from fellas in vietnam, but it can be anything that sets it off, and knowing that you might never have kids again because you drove a truck full of ammo which had DU is one of them.
It's very touchy feely now tho. I had to fill in an incident report because I worked in a building and now they have found asbestos in it. I also used to drive a vehicle that they have now deemed to be too loud in the cab above 80kmh. I now fill in an incident report incase I lose my hearing in the future.
Old 21-03-2006, 01:44 PM   #24
gozza
gozza's Avatar
the purpose of the 303 was to injure the enemy but not kill them......hence going stright thru and leaving a clean wound.... instead of 1 person taken out of action......... this living but useless soldier would have to be carried by at least 2 more soldiers thus rendering them inactive
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 02:06 PM   #25
BA_Turbs
Allan Smithee
BA_Turbs's Avatar
Don't Victoria Police use hollow point rounds?
Someone better tell the Swiss about this.
1974 XB Falcon 500 Station Wagon - 250, 3 speed auto and running like a 2015 model
1999 AU Wagon Petrol/LPG - Cheap run around, but still a great car!
2014 PX XLT Ranger 4x4 Auto getting set up as an off road touring rig
BA_Turbs is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 02:23 PM   #26
flappist
Not ALL of Victoria is a war zone, just some of the suburbs of Melbourne :
Old 21-03-2006, 02:30 PM   #27
Gunns
Gunns's Avatar
They are a .38 solid round.
Where did I say anything about a 303?
The point is a solid round is less humain than a hollow point.
If it was me, I would want a round the goes through kevlar and body armor rather than getting stuck in it!
Old 21-03-2006, 02:43 PM   #28
flappist
Before this goes too bezerk. The Hague convention was in 1874. Cartridge rifles still used black powder and high velocity weapons did not exist nor did much in the way of medical help for gunshot wounds.
The actual wording is:
The right of belligerents to adopt means of injuring the enemy is not
unlimited.
Article 23
Besides the prohibitions provided by special Conventions, it is especially
prohibited:--
(a.) To employ poison or poisoned arms;
(b.) To kill or wound treacherously individuals belonging to the hostile
nation or army;
(c.) To kill or wound an enemy who, having laid down arms, or having no
longer means of defence, has surrendered at discretion;
(d.) to declare that no quarter will be given;
(e.) To employ arms, projectiles, or material of a nature to cause
superfluous injury;
(f.) To make improper use of a flag of truce, the national flag, or
military ensigns and the enemy's uniform, as well as the distinctive badges
of the Geneva Convention;
(g.) To destroy or seize the enemy's property, unless such destruction or
seizure be imperatively demanded by the necessities of war.
It applies to war not peace and technology has changed a lot since then.
This is a very morbid subject and this is probably not the right place for it....
Old 21-03-2006, 02:55 PM   #29
gozza
gozza's Avatar
i never said you said anything about the 303
your post brought up the thought
Old 21-03-2006, 02:56 PM   #30
Mack 6
SUMP PLUG
Mack 6's Avatar
Google is your friend hey flappist.
The old rounds are where full metal jacket comes from. Jacketed rounds that pass straight through the shootee.
Because a hollow point will enter, mushroom out and bounce around a bit doing severely buggered up stuff to your insides, it's considered to be too inhumane.
As Flappist wsays, these are armed conflict rules of engagment, not necessarily applicable to everyday shootings in the melbourne and sydney CBD's
