Old 08-01-2015, 01:56 PM   #1
Tonz
Default Horns again.
from SA>
More than 260 people have signed a petition to the State Government calling for train drivers to use horns only for emergencies, such as a person or animal on the track.
The Transport Department replaced horns in its 11 electric trains, costing $66,000, between May and November following community complaints.
The department said the new horns were between 88 to 90 decibels – the same volume as the previous diesel trains – and met Environment Protection Authority guidelines.
The previous electric train horns were up to 97 decibels.
Marino petitioner Amanda Aloia said the horns were “loud, high-pitched and, quite frankly, frightening”.
what the fruitcake, my Stebel (Italian?) horns are rated @139Db and no where as loud as these babies. Can someone clarify.
Wonder how I get a set of ex South Aus train horns.
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2015, 02:56 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Horns again.
https://www.youtube.com/watch?annota...&v=5goZ7n_N7Cs
Old 08-01-2015, 03:51 PM   #3
raceteam
You need to check the distance from source that it is measured at - the Stebel horns are usually measured at 100mm from the horn. Probably find that it is measured at 10 meters or something for the train.
EDIT: It seems in USA they measure train horns at 100 feet from the source, so it may be a similar distance to that - 35 meters perhaps?
raceteam is offline   Reply With Quote Multi-Quote with this Post
