Old 15-08-2011, 12:59 AM   #1
Trevor G
Default Exhaust Particulate Filters
Do the Fiesta diesels (Econetic or otherwise) have exhaust particulate filters?
If so, what is the service routine for them?
Trevor G
Trevor G is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 06:56 AM   #2
Russ
Russ's Avatar
Default Re: Exhaust Particulate Filters
Trevor G
Yes they do have a DPF. There is no real service routine for the filters as the cars are designed to do their own cleaning (DPF regeneration). The normal service interval for oil, filters etc..... is 12 months / 15,000kms. I can tell you from experience with a DPF fitted vehicle that they are far from ideal if you do a lot of city driving so be sure you do your homework before making your choice.
DPF regeneration process explained below
http://www.theaa.com/motoring_advice...e-filters.html
Old 15-08-2011, 09:58 AM   #3
Trevor G
I think we will then find that they do have a service routine because they use a very expensive liquid catalyst, the trade name being EOLYS fluid (but Ford might call it something else).
I will have to investigate via the service centre, then.
Thanks
TG
Old 15-08-2011, 07:37 PM   #4
290v
290v
290v's Avatar
Standard service but make sure you use the right engine Oil as the wrong oil will destroy them and are very expensive to replace
BA GT 2003 Silhouette
4 Speed Auto
290v is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 08:09 PM   #5
Trevor G
I have plenty of experience with them on Peugeot and Citroen.
What I want is more information regarding Ford's use of them, whether they use a liquid catalyst or a solid one retained in the DPF itself.
Surely someone can tell me authoritatively?
Any takers?
