Old 04-01-2008, 02:38 PM   #1
gilto
Default Fadi - i NEARLY fixed my 6 stacker
Hi Fadi,
My mate got a cd jammed in my stacker. I took it all apart and got out the 2 jammed cd's in slot 1 and took out the cd in slot 2 as well.
Put it all back together and slots 3-6 play no problem. I then ejected the slots and pressed load....
Please wait...then slot 1 sia dload...so I did and the unit won't register there is a cd there. So i press load again and it flashes slot 1...i put in another cd...still not registering. So I now have 2 cd's in slot 1 again.
Back to the drawing board....
When I take the unit out again I will release the cd's. Then should all the white slots for the cd's be flat or should slot 1 and 2 be slightly raised?? This was the case the first time I got out the jammed cd's....everything looked fine to the eye...anything I am missing???
Thanks mate,
Gilto
gilto is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 02:51 PM   #2
FADI75
Sponsor
Originally Posted by gilto
Hi Fadi,
Thanks mate,
Gilto
Gilto
the best solution is using a new part which's the whole cd mech. there is no easy fix with these things. $450.00 all inc fitted back in your car. or $406.00 supplied only
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
