KenneBell Australia
I have seen in many occassions during AFF drag days and regular street meets that people are really getting into the sport of drag racing with their streeters and enjoying themselves.
This is awesome - but I have a handy tip for the "street" cars that are equipped with modern LSD differentials. Ever seen the guy at the drags with the LSD differential, but then you see it "singling out" (i.e only one wheel smoking). THIS IS DESTROYING THE LSD UNIT, POTENTIALLY COSTING YOU $$$$!! A limited slip differential is just that - limited slip. It is designed for driver comfort and control when applying differential (a turn, which will by nature of physics cause the INSIDE wheel to make fewer turns than the outside wheel.) The slip inside the LSD is featured by a set of wave washers in the Dana M86 as fitted to all B series FPV, V8 and T6 applications, and tapered friction cones 80 series Borg warner style unit in the NA BA6 and AU and earlier series. The LSD is only designed to be "working" on a turn as stated above - so here is why a big long burnout or "donuts" are no good. Scenario 1 - You are in the water, ripping it up, your mates are watching, your blood is pumping, there are at least 4-20 gorgeous girls watching, you are feeling at least ten feet tall. So you get em nice and hot, and decide to move forward into the dry stuff. WELL, what is about to happen is this - whilst both wheels may be spinning freely, the moment the car meets"dry land", ONE wheel usually hits the dry stuff first, followed by the other, which may still be in the water. Usually, 9 times out of 10 and depending upon car weight and power, the wheel in the DRY has to make a bigger effort to turn. If that effort cannot be sustained, the wheel will lock and stop (the start of the one wheel burnout) and ALL the power will be diverted to the wheel that is enjoying less friction. Meaning, a cone or clutch inside the LSD unit can go from 0 rpm to 4-8000rpm in an instant, creating heat that will permanently damage an LSD. Ok - i hear you guys piping up "my mate has an LSD and such and such re-built it and tightened it up, and it limo's fine, etc etc." They can continually work - but the shock load can "peen" the cones in an 80 series Borg warner unit, and will unload the concave preload on a DanaM86 wave washer in a B series. Either way, it is wearing out your LSD prematurely. Sooner or later, your "mate" will be up for some $$$. Seeing the diff man for an LSD repair is like seeing the Tax man. You dont WANT to do it, but if you want smooth sailing, you HAVE to do it! Now, im happy to rebuild diffs as long as guys break them - but in this day and age is is important to get the most from your dollar. How do i do a burnout? well, its no longer called a burnout, the new word is simply a "BURN". 1 - pull into the water evenly, i.e both wheels in same amount of water - the guy at the startling normally does a pretty good job of this, and will wave you out and back in if you have fudged it. 2 - light it up, but keep the car in the water, burn the tyres until you see smoke, and slowly creep forward. BUT from this point, if the car is equipped with a spool, throw your foot down hard and do a "power" burn, (spools are not legal for road use) If it has an LSD, pull most of the throttle back, let the car go forward to dryness then LIFT. If the car wants to go sideways in the burn, get off it - if a wheel grabs dry, you will be in big diff trouble one day............better to save it then doing a one wheel hero burn, which should sound like the sound of a cash register ringing the bells....... I hope this helps you guys - building all our own Diffs and LSD's in house and racing them has taught us this valuable info - hope it can help you guys. See you at the track! :eclipsee_
Bluepower Racing Developments Proud Australian Distributors of Kenne Bell superchargers The Quickest, The Fastest, The Baddest Boss Blower of all. www.bluepower.com.au |
Hello
Thanks Chris, good advice. Ill bear that in mind with my new LSD!
2008 FPV TERRITORY F6-X Silhouette, window tint, roof racks, 3rd row seats, ROH Mantis 19s, black custom plates 'FPVF6X' and no stripes. ![]() ![]() |
Force Fed Fords
Thanks Chris, another thing to file away for day at Heathcote soon. So much too learn.
2021 Focus ST-3 Mountune Enhanced |
NO donuts, yea right where the fun in that.
Thats some great advice Chris, great of you to enlighten us all! Ripping a big smoky is so much fun, but also so expensive as well! I must admit upgrading to a LSD took me a bit of getting used to, especially in the wet. But as you said, they are designed for safety. Great write up!
Evan |
Hmmmmm Mulberry....
I put M/T steet E/T's behind by XBGT with LSD.
2 burnouts and up for new clutches. Tyres got sticky, One more than the other. Started to single spin and glazed the clutch pack. Lesson learn't. I had no real trouble with normal radials, but the switch to some sticky tyres cost me. |
My missus broke my Borg Warner LSD at the drags and the axle. She left the hole and "Happy Wheeled" and when she hit 2nd the passenger side tried to slip but the VHT would'nt let it and it ripped my clutches to peices and broke an axle. But it is all good and tight now, almost locker style without the corner skidding.
What would forum's be without post whoring know it all's......... |
#8 | |||
Back to Le Frenchy
Thanks for that info, very valuable with the drag day coming up.
#9 | |||
just a quick question though what about the people with single spinners if we get both spinning and heaps of tyre smoke are we doing damage to our diff as well jason
![]() Join Date: Jan 2005
Cheers for the info, i'm sure it'll save alot of people money down the track!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
THIS IS SPARTA!!
Thats some great information there Chris, as i have been one of those racers with little experience doing the burn incorrectly :(
Thankyou for sharing that with us, i will put the new information into practice next time im at the strip. ![]() |
#12 | ||
Bluepower enhanced GT
First hand on what you were on about Chris......
Just had the Diff rebuilt today - the LSD was fubar'ed as the cluch plates were fried - $2800 big ones (with 4.10 replacement included ![]() Atleast it is done now and will have enough driven k's to smoke them at Heathcote once again........ ![]() Cheers Damo |
DPC PERFORMANCE Race prep
sorry lost ya when ya mentioned the pretty girls
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club |
#14 | ||
I have a manual and found that when I do a small burnout the car will inevitably move forward slightly or sideways. I have not tried heel and toe (keeping one foot on the break). Its something i want to try next time but just trying to get the technique right is pretty difficult. Is this the best way to do a burnout whilst keeping the car stationary for manual? Are there any other methods?
Usually when i start to loose the backend i stop my burnout....this can be within 3-5 seconds.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#15 | |||
#16 | |||
Thats how i do it, though i use second gear for burnouts, about 3500 rpm, drop the clutch, foot on brake and hold revs to 3500 at least till they start smoking up, then off with the brake and let it come out of the burnout. |
#17 | ||
brake with left or right?
(Obviously I'm not a hoon)
#18 | |||
#19 | ||
lol. Sorry that came out wrong. The reason I ask about the right is because thats what the heel and toe technique woudl use. But dam difficult to master for a newbee like me.
#20 | |||
LOL mate, what are you implying? ![]() |
#21 | |||
#22 | |||
#23 | |||
#24 | |||
#25 | |||
RIP Craig - 13/11/08
![]() Join Date: Feb 2005
Once the tyres are spinning nicely and your not over revving release your left foot and slowly move forward to get out of the wet stuff and try to leave 2 nice rubber marks on the race track. If the car moves sideways don't be too concerned just keep it under control with your steering wheel. Cheers Craig |
#26 | ||
Good right up chris!
Heritage Green EL Ghia Black AUII XR8 Ute |
#27 | |||
Ute Forum Moderator
![]() Join Date: Dec 2004
#28 | |||
Excellent writeup!
#29 | |||
Neglecting the P250
Blue Power Racing Developments
Great work and not a bad bloke ;) AUIII XR8 Pursuit 250 241 RWKW with Advance Headers, Twin 2.5" Exhaust, G&D CAI, Walbro Pump, Crow Cam, Custom Tune |
#30 | |||
For those that don't know a chap let his mate have a spin at DECA and thought he was cool spinning the wheels but was in fact spinning the c r a p out of his clutch.....the result a clutch that exploded and took just about everything out in the clutch area and some, around $15K damage, gearbox, engine block (it blew off half the block at the back), starter motor, exhaust, some wiring, 1 x side skirt and a few other things i can't remember. All in all a VERY expensive lesson. Even when watching drag racing you will never see me anywhere near the clutch area in the burnout area or when the car is launching, it's very dangerous. |
