Old 15-03-2007, 08:37 PM   #1
bonspeed
bonspeed's Avatar
Default Commodore 6's
howdy guys I'm having one of those work mate argument's and i'm hoping someone here can help me, I know its commodores but if you could help me out that would be great, OK here goes: Are the six cylinder 3.8 injected motors fitted in a vr to vy called an ecotec?
bonspeed is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:41 PM   #2
castek
vs up to vx i am 100% sure its ecotec. vn to vr was a buik 6. vz ues alloytec didnt they?
castek is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:42 PM   #3
XRLightening
XRLightening's Avatar
As far as I know you are right
Some say if he could be bothered he could solve the Da Vinci Code in 43 seconds.
We just know him as THE MANTIS
FPV & XR Owners Club of Victoria
Daily Drive:
2005 GU IV Patrol, 4.8l Petrol, Manual, Steel Bullbar, Towbar, Electronic Brakes and Cargo Barrier.
Toy Drive:
1968 XT Falcon Ute - Dead Stock, Original and ALWAYS Garaged
XRLightening is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:43 PM   #4
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
I think maybe VS series II was ecotec (I think series I wasnt, not 100% sure though) and up to VX as has already been said, got a mate with a VR II and it isnt ecotec
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:49 PM   #5
Smoke Pursuit
VS series 1 started ECOTEC
Smoke Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:52 PM   #6
HgXR6T
I think VS series 1 through to VY series 2 was all ecotec.
VN to VS series 1 was buick.
Only VZ onwards is alloytec.
HgXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:52 PM   #7
bonspeed
bonspeed's Avatar
OK cool ill clarify a little more, said workmate owns a vr, I told him it had a ecotec in it and he said it didn't, Who's right?
I thought an ecotec was just a fancy cover holden put on the later motors to make them look different? mabee a different plenum too?
Old 15-03-2007, 08:55 PM   #8
Homer1
Homer1's Avatar
AFAIK its the same old hoary lump ie. Buick V6. Ecotec was just a name to make that lump sound more appealing
Homer1 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 08:58 PM   #9
HgXR6T
I think power rose from 130 kw to around 147 kw with the ecotec. But lost some low down torque, or so say all the VN owners.
Had some different engine internals iirc. Something about being more effiecient and lowering emissions, probably just holden bs.
Quoted from wikipedia
http://en.wikipedia.org/wiki/Holden_VS_Commodore
"The new ecotec engine was not at its core the standard Buick V6 found in the VR. They started off with a totally new engine and only retained the dimensions of bore and stroke. The ecotec had 13% more power over the VR and 5% better fuel economy. The compression ratio was also increased from 8.5:1 on the VR to 9.4:1 on the VS. Also cross bolted mains are used in the ecotec with the same crank retained from the VR. The block was decked 1" and also the ecotec featured shorter, lighter rods with tin plated pistons and a floating pin design. The head design was revised greatly from the VR with the ECOTEC now features symmetrical ports with larger intake and exhaust valves. The end result was an engine that put out 147 kW, a 17 kW improvement on the VR, however the 0-100 km time of the new ecotec VS was only better than the VR's by 0.2 of a second."
Old 15-03-2007, 09:00 PM   #10
bonspeed
bonspeed's Avatar
ha ha thats what i told him.
Old 15-03-2007, 09:02 PM   #11
bonspeed
bonspeed's Avatar
Well looks like im wrong then, its got the same crank in it though.
Old 15-03-2007, 09:06 PM   #12
bonspeed
bonspeed's Avatar
Bugger bet my left nut on that one to.
Old 15-03-2007, 09:51 PM   #13
redranga
I think it was called ecotec because it was the first commy to have sequential firing of the injectors which gives better economy
redranga is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 09:59 PM   #14
MethodX
MethodX's Avatar
From the book - Holden the classic models
VS- Commodore
Major modifications to the 3.8 litre 6 made it virtually a new unit.
Power was up 13%.
The engine had a new cylinder block and manifolds, reshaped cylinder heads, lightweight pistons and its compression ratio was increased to 9.4:1.
The engine was a good deal smoother than the VN unit.
Holden gave its 'new' V6 the anacronym ecotec, for emmissions and consumption optimisation TECHnology.
MethodX is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 12:42 AM   #15
SPK-250
SPK-250's Avatar
It's actually VR series 2 that started the ECOTEC. VN up to series 1 VR had the early motors. The ecotec has shorter deck height, pistons and rods along with siamesed ports on the cylinder heads.
What would forum's be without post whoring know it all's.........
SPK-250 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 05:22 AM   #16
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
My son has a VR series II 12/94 its not a ECOTEC.
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 05:59 AM   #17
Jeeepers
Merry Xmas To All
Jeeepers's Avatar
Whatever they are, 2 tried me last night. One each side of me.... Suckers.....
Jeeepers is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 07:24 AM   #18
LTDHO
The one and only
LTDHO's Avatar
Ecotech came out in VS1.
If ya mate know Holdens, then he should know this.
I worked for a company that was working on the developement of some components back in early/mid 90's.
Tuned by CVE Performance
Old 16-03-2007, 09:17 AM   #19
GXL078
GXL078's Avatar
The ECOTEC was a revised engine that Holden had a lot of problems with when it was introduced. Used heaps of oil apparently due to "low friction internals" I believe. There are 4 cylinder GM motors are called ECOTEC as well, eg in the Vectra.
GXL078 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 12:22 PM   #20
VQST80
The Insider
VQST80's Avatar
S1 VS ecotech was born.
It has a shorter stroke than the older buick engines
Go have a look at st comms for info..
VQST80 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 03:44 PM   #21
Beetus
Now drifting a falcon
Beetus's Avatar
the ecotechs were also used in one one of the models that also uses the alloy tech, u can usually tell how by the badges, one will have "v6 alloytech" and some will have "v6" the ones with just the v6 are ecotech but they squezzed 152kw out of that one. ecotech started in the vs1, totally revised engine.
Beetus is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 03:52 PM   #22
XR8-260
I think you are refering to the VY and VZ models. They both look similar but it is the VY that has the ecotec (152kw) and the VZ that has the alloytec (175/172kw).
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 04:04 PM   #23
Beetus
Beetus's Avatar
cheers wasnt to sure on that, probably cause i dont really care but yeh thanks.
Old 16-03-2007, 04:35 PM   #24
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
I think there is a difference in the badging of the 190 alloytec to the 175 too.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 05:01 PM   #25
PoMmYwOG
being an ex commodore nut(i have seen the light) i can ensure you the ecotech came in from the vs series 1 up untill the last vy series 2. The ecotech IMO was a much better engine than the buick, i had a vp before my vs and the vs was much smoother and had heaps better top end , although the vp would launch harder off the line. The buick was a very rough engine, i had a vr next to me at the lights yesterday , damn it was noisy and rattly.
10' FG XT in Edge (Company Car)
6Spd ZF!!
06' Mazda SP23
5spd auto
Luxury pack
PoMmYwOG is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 05:25 PM   #26
Ryan
Buick 3800s, Ecotecs meh.
As far as Im concerned, the best 6 to ever go into a Commodore, was the Nissan RB30.
I'm not biased though. hehehe
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 05:28 PM   #27
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
Now that would have to be the most intelligent post today. :eclipsee_
I'll have one in white with the pop up front thanks
Old 16-03-2007, 06:47 PM   #28
Gobes32
Gobes32's Avatar
If only Nissan had built the VL Calais instead of holden............ Would probably still own mine.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 07:07 PM   #29
GXL078
GXL078's Avatar
I wish I had a dollar for everytime I have said that.
Old 16-03-2007, 08:35 PM   #30
Sladdo
COMING SOON: Sleeper XF
Sladdo's Avatar
The VN Series 1 3800 went the 'hardest' out of other Commodore motors. There have been reports a stock VN Series 1 3800 has beaten a VZ ALLOYTEC in a race & i wouldnt be surprised if it did. Also reports of VN's pulling 250Km/h stock without the speed limiter....
As with VR & VS, the VR had the Buick 3800 & the VS had the ECOTEC & having a VR & VS in the car yard i work at i can tell you the Buick 3800 in the VR is a harsher/louder motor than the ECOTEC & id rather a VR over a VS anyday. I love giving the VR a rev cause it sounds so beautiful. And having been in both cars when being revved at 5500rpm+ the VR seems to want more & more.
Sladdo is offline   Reply With Quote Multi-Quote with this Post
