Old 25-01-2007, 05:50 PM   #1
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
Default B&M Shifter Install - Long weekend Job
Hey All,
Well i finally got the whole weekend to myself, no work, no other work. just time to work on my car.
For anyone interested i will write up instructions at the completion of the install, todays half day progress (busy wiring up other crap on the todo list)
Removed old shift
removed old linkage
installed 3/4 of mega shifter
1/2 installed cable
1/2 installed bracket
for those who dont know about the megashifter.....
its pretty much the same as any other shifter except.
a) its chrome
b) it has a finger release instead of button like on e series
c) it is a hybrid between tip tronic & auto
ill explain part C
P, R, N & drive all move as norm (you need to pull release pin with fingers)
however once you get into N or D you just push the T piece of the shifter Forward & Backwards to Cycle UP or DOWN the gears...
to change down gears while driving
go to drive with finger release (as normal) then ....
TAP T piece down to go to 3 (automatically centers t piece again)
TAP T piece down to go to 2 (automatically centers t piece again)
TAP T piece down to go to 1 (automatically centers t piece again)
go from 1 to D
TAP T piece up to go to 2 (automatically centers t piece again)
TAP T piece up to go to 3 (automatically centers t piece again)
TAP T piece up to go to D (automatically centers t piece again)
ive never used or installed a B&M so it will be interesting to see if it feels good to drive or wether it gives me the shits.
anyhow back to it.
later
brad
2005 - BA mk 2 - XR6T - 4.0ltr Turbo - 6 Speed Manual
Blue Power Airbox, Sunroof, Typhoon Wheels, Brembos, Prem Sound, Momo Chunky Wheel, Genuine FPV Gauge Holder, Whiteline Swaybars, Lowered, Tinted Windows, 60lb Injectors, Plazmaman Cooler, Hot Side & Under Battery Pipes, 4" Dump & Cat, Process West Surge Tank & Bosch 044, Turbo Inline Oil Filter
BRADMAN is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 10:43 PM   #2
Maximus
ED XR6
Maximus's Avatar
Sounds interesting mate, Be sure to post some images, Even a video would be awesome.
Maximus is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 11:44 PM   #3
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
yeah ill get some pics up 2moz sometime.
at the same time im also doing the following
Finish monster tach & shift light reinstall
Finish cruise control install
Finish racing seat bracket painting
Finish boot & sub layout (10th design)
Finish PS2 reinstall
Replace brakes all round
Replace cracked instrument panel plastic
The poor babies up on bricks at moment....no ford should be taken off the road for long :(
yeah big list....what a pitty wreakers arent open 2moz. wont get jack didley done. ohh well.
later
brad
Old 25-01-2007, 11:47 PM   #4
starkersEB
starkersEB's Avatar
Hey mate are you using a BTR trans cos im thinking about putting my B&M quicksilver into my EB but ive never heard of anyone doing it to a BTR id love to see how you pull it off.
starkersEB is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 11:58 PM   #5
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
well after a lot of thinking and trials....the best i can get is all gears except 1st.
this is mounted to standard 4 speed EA auto transmission.
might i add....i must only be out by like 2 tenths of a bees dick. cos it needs like 5mm more pull to swing into 1st (tested by pushing linkage at gearbox with little finger)
i think ive tried all ways to get it to work, ill have 1 more go 2moz. then im giving up.
my transmission is nearly stuffed anyways (slipping, clunky)
so what im thinking of doing sunday is ripping her out n getting an AU or AU2 transmission instead. maybe it will be easier to hook up to shifter.
the b&m are good, but the connection to the transmission is a pain in the *** cos the lazy engineers at b&m only deal with US cars. which means custom bits.
hey does anyone know or have done
EA drive shaft....connected to AU transmission.....connected to EA motor & ECU?
or do i need to replace engine as well as gearbox & also ECU?
thanks
brad
Old 26-01-2007, 12:28 AM   #6
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
ohh i thought i might add.....after i have got this shifter working, i will design a simple circuit to display what gear shifter is currently in, that or mod EA2BA's gear ID circuit.
all it would need is a set of micro switches on each PIN step of the shifter, as the shifters PIN step closes the switch which would associate to each gear level it would display the driver letter on a single led display (same as EA2BA).
will look into it asap
nite
brad
Old 26-01-2007, 11:36 AM   #7
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
I was thinking of doing this what B&M shifter are you using I also Have a EA 4speed...
I really want a BF 6speed in the EA(along with a BF/A engine) But I don't have the money for it....
Is there anyway to make the EA box triptonic Like BA/BF's?
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Soundstream speakers amp and subs
Lowered
DL LTD rims
: thats it!
For the moment... :
NC_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 11:43 AM   #8
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
Im using the B&M Mega Shifter
http://www.bmracing.com/index.php?id...subcat=1&pid=7
Yeah BF 6speed sounds good. but this b&m shifter can only do max 4 speed
hence me wanting to get the au gearbox asap (from memory they are still 4 speed)
brad
Old 26-01-2007, 11:49 AM   #9
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
Yeah still 4speed 6 didn't come in until BF I think...
oh yeah I like that one... But I like the one that goes from N to 1 2 3 4 instead of N to 4 3 2 1 you have to show pics soon...
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Lowered
DL LTD rims
: thats it!
For the moment... :
Old 26-01-2007, 11:57 AM   #10
Gubas
- BOOYEH -
Gubas's Avatar
PM TUFFED.
He has a B&M shifter in his ED 5.0ltr.
Taken from his for sale thread,
Originally Posted by TUFFED
B and M shifter uses an adjustable solid link to the gear box. pics are too big to post. any questians feel free to ask.
1993 EBII Fairmont Turbo T04e 7 psi
Gubas is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 12:15 PM   #11
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
ok ive had no luck, so im moving onto another job in the todo list.
heres some photos anyhow
brad
Old 26-01-2007, 12:17 PM   #12
fairmont1998
fairmont1998's Avatar
Yes, fit a BA or BF shifter and control circuit, EA2BA and Ghia5L have both done it, there are threads on here about it.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 12:23 PM   #13
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
Thank you for helping me I will search for there threads...
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Lowered
DL LTD rims
: thats it!
For the moment... :
Old 26-01-2007, 12:25 PM   #14
Sourbastard
Contributing Member
Sourbastard's Avatar
Pre flight check!
Gtech! Check!
Monsta Tacho! Check!
Plastic Check Plate carpet protector! Check!
Cleared for launch.
1965 XP Falcon Deluxe Sedan
2003 BA Fairlane G220
Old 26-01-2007, 12:37 PM   #15
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
If the shifter is stumping you,I think the AU auto install is best forgotten.
Why not try one of these steering wheels,would fit the theme of the interior well..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 01:07 PM   #16
fairmont1998
Back on topic guys.
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 26-01-2007, 02:28 PM   #17
OED666
OED666's Avatar
you certainly have a list of jobs to finish off... hang in there, you will get there one day. i know what its like to have a huge list of things.
just a question about the shifter, and dont think i am having a go. but what benefits are the for using this type of shifter???
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 02:52 PM   #18
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
you don't have to press any buttons to change it from 1,2,3 just hit backwards and then to change down gears hit it forwards 1,2,3 would work best with a shift kitted auto not a standard one. thhey work well in worked cars but stock im not so sure.
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 03:30 PM   #19
Walkinshaw
Two > One
Walkinshaw's Avatar
ohhhhhh shiney
Old 26-01-2007, 11:58 PM   #20
fairmont1998
The shifter will only ratchet forward or back one gear at a time, so when you are manually shifting you cannot miss a gear or when fitted to a trimatic like I had one in my HZ, you can't do the dreaded second to neutral shift (trimatic has no detent from Drive to Neutral). Leaves you free to concentrate on other things when you're not trying to hit the right gear.
And as Dan said... Mmmmmm, shiney :P
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 27-01-2007, 09:59 AM   #21
BRADMAN
BA Mk2 XR6 Turbo
BRADMAN's Avatar
the shifter is not so much as stumping me, its giving me the shits, however the path that tuffed went down is a much better idea, my problem was i was trying to mount right on gearbox, instead of mixing ford & b&m parts.
the benifits are what fairmont1998 & ebmanul was saying, and yes i know they better suite hotted cars, and i would love an old school, but the fact of the matter is the ea is my pride & joy (sometimes) so why not put the cool old school parts (in my mind) into the ea & be happy with a mix of the 2.
if i could buy them in flat black/grey i would have, but they come standard in chrome
ohh might i add, if worst comes to worst & i cant get all gear lined correctly, a trans specialist said he could finish the job for me. (either way cant really loose)
anyhow off to wreakers to get some bits n pieces
later
brad
Old 27-01-2007, 08:26 PM   #22
BJ
You do know they wont work with a 4 speed auto don't you??.
BJ is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 08:43 PM   #23
*rayman*
454 Power
*rayman*'s Avatar
i think he might now....
DAILY - 00 75th Anniversary Futura
TOY - 68 SS 454 Camaro
*rayman* is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 11:35 PM   #24
[Tonko]
What's green is gold
[Tonko]'s Avatar
i have some 12 slotters for sale, they will go well with the woodgrain steering wheel, and its an EA so might just tie them together
/sarcasm
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 12:05 AM   #25
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Eeeeaaasssy. Dont go bagging the EA. As crap as they may be, they are the leaders of this club. Only joking coz i love me EA.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping".
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 12:29 AM   #26
starkersEB
starkersEB's Avatar
Actually they will. Well i know on the Quicksilver there is a pin you pull out to make it a four speed shifter, i think its for one of the chev boxes.
Old 28-01-2007, 12:39 AM   #27
Jasinex
Jasinex's Avatar
it would look pro... but i have seen it installed in both 3 speed and 4 speed boxes... but i dont know how they did it..
jasinex
EA Series 2
now with fast parts added...
Stage 1: Buy car. with money.
Stage 2: Put in Wade Custom Cam, Crow Double Valve springs, High Flow Head, 3.23 LSD, 2.5" mandrell bent with Mercury muffler and custom made CAT, iridium plugs, nolothane bushes, Koni suspension, CAI.. NOW WITH MPFI....OHHH YEAHHH!!
Stage 3: More engine mods.. and a fresh new look... can't wait.. :eclipsee_ : :Reverend:
15.43 @ 89 mph - Willowbank Raceway 07/03/2007
Jasinex is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 08:11 AM   #28
Racecraft
they call me Tibbo
Racecraft's Avatar
the megaa shifter as far as I know is not suitable for the BTR 4 speed... alot of the B&M jobbies are universal for 2-->4 speeds but I don't think the Mega Shifter is one of them..
EDIT: looking at the link you posted it doesn't list the BTR as an application :P
Old 28-01-2007, 11:54 AM   #29
NC_GHIA
FirstOnRaceDay
NC_GHIA's Avatar
I second that...
MY BRAND NEW RIDE
NC Fairlane GHIA
Series II
I6.
Mods. 2.5" cat back
Clarion HU
Lowered
DL LTD rims
: thats it!
For the moment... :
Old 28-01-2007, 12:15 PM   #30
66 coupe
around the place
66 coupe's Avatar
Technically, the shifter will and wont work on the 4speed.
It will in the way that it does support 4 speed transmissions and with a bit of messing around you can make a linkage and bracket to suit the BTR, but you need to work out and drill the gear linkage to give the lever the right arc.You need 2 people for the job, one inside the car going through the gears and one under the car lining up the linkage and cable through each gear to find a common point on the linkage arm, that follows the same arc as the shifter cable moves.
The shifter also required custom linkages and brackets to suit the FMX in my car. A bit of messing around modifying a C4 lever but ended up getting it right.
It wont work on the BTR in the way that the ecu decides when the trans will change gears, not the shifter position, therefore you can be driving and have the shifter in 4th, but the ecu will only select the gear it thinks the trans should be in dependant on road speed, rpm and load
Also make sure you get some tin and close the old hole in the tunnel or you will get a lot of heat and noise up through there, and the cops dont really like it either..
GPS Tracker for your vehicle - PM me for info
66 coupe is offline   Reply With Quote Multi-Quote with this Post
