G'Day, I have an 87 KC Laser that is running rough and is gutless. I have changed plugs, leads, distributor cap and rotor arm. I have also stripped down and cleaned the carby. Has anyone got any ideas. Thanks.
Over Thinker
have to wait for vippin's input
might be a valve burnt or low compression whats the compression figures if electroninc the coil or dissy module if injected buy new injectors or injector clean
My car goes Brumm Brumm |
I hav'nt done any compression testing yet, but i am starting to think along the lines of a valve or a piston.
What a performer!
Yeah can't be too precise on that, might be an idea to get it looked at if you've done all the general things.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
Over Thinker
a vaccume leak
check all the vaccume lines vaccume advance throttle body and anti pollution air flow meter , o2 sensor, or even a clogged catalytic converter
Dirty Hands, I'll give all those things you mentioned a check at the weekend. Thanks
Over Thinker
Vippin knows more about lasers post up the figures and what you find
you can be sure to get help in here ....to get your car to run better
Have you given it an oil change. sometimes the oil gets too gluggy to pump up to the overhead cams?
