08-11-2006, 06:36 PM | #1 | |||
Formerly mad_ed_wagon
(dont know if this is the right place to post it but here goes)
Ok heres the problem The belts in my EB have started squealing so i decided to leave it sitting in the yard till i have time to work on it Last time i drove it was Wednesday? I think since then its been sitting in the yard until monday when i went to start it and the battery was completly dead! i mean not even central locking worked or the interior lamps! So what could be causing this? I have put a TV/DVD system in and a pioneer head unit but it doesnt seem to be causing the problem from what i know I put the stereo system in the day after i got it so i'm unsure if it had this problem from when i bought it, and it was being driven as a daily at that time so it didnt have time to run out I had the same problem where the battery went dead when i was doing the head gasket in it back a few weeks ago So could there be something draining the battery that i dont know about? or could it be the battery it's self thats gone? The dvd system is connected to the cigarete lighter so it cuts off power to it when the cars off so i highly doubt that would be causing the problem Anyway thanks in advance for your help
2004 BA FALCON XT/GHIA WAGON Build thread coming soon! Quote:
08-11-2006, 06:57 PM | #2 | ||
could be the battery isn't holding a charge or the alternator isn't charging it up fully.
charge the battery then get it load tested. check the alternator output. squeaking belt might be your alternator belt - adjust and/or replace it. |
08-11-2006, 07:06 PM | #3 | ||||
08-11-2006, 07:18 PM | #4 | ||
V8 Ute V8 Boat
if you keep sitting in your car and watching DVDs that kills it very quick especialy if you have 2 amps like me dies in around 5 houres
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
08-11-2006, 07:23 PM | #5 | ||
mine dose the same. im on my 3rd battery atm witch will last no more then a week of sitting there and it's a orbital dry cell. : if any one has any info on it.
thanks LUKE |
08-11-2006, 08:10 PM | #6 | ||
you probably just need a new battery.
08-11-2006, 08:22 PM | #7 | ||||
i will try changing the battery and see what happens though
08-11-2006, 09:18 PM | #8 | ||
rofl copter
deleted
GQ patrol.
.... thats all |
08-11-2006, 09:38 PM | #9 | ||
Performance moderator
Check load on battery when everything is tuned off ???
Adjust belt, they run very tight.. Due to belt just being big enough... I would seriousl consider fitting E.L type serointine belt and up grading alternator ... The std belt only just works with std load...
08-11-2006, 10:03 PM | #10 | ||
AU II XR8
just get a new battery
09-11-2006, 01:57 AM | #11 | ||
just a little krazy
I have a similar problem with my ea, I don't have the battery drain on me as I try to drive it everyday, but I do have the typical ea squeal. I have just had an amp, 12" sub and new speakers installed all round and I have the squealing. I have replaced my fan belt, but the car only squeals when the volts are below the second line (from the fully charged side). My partner gets in a uses the pressure cleaner and blasts my alternator and that solves the problem for a few days. Another problem could be the power steering pump leaking oil onto the alternator, had that problem to and once we had replaced all the seals in the PS pump the squealing stopped, it has since come back but it is not the PS pump or the belts. New alternator is the next option.
:evil_laug Its not what you drive, its how you drive it that counts!! :Up_to_som |
09-11-2006, 12:23 PM | #12 | |||
Im going for an AU engine in short time (I doubt the EB one would last when i put boost thru it LOL its already on its last legs and has 246,000kms), Im just trying to work on a quick fix for it so ill just tighten it and see what it does, it wasnt squealing before i messed around with it, i just need to tighten it me thinks
I have a spare battery in that garage ill chuck in for now and see if it makes any differance, dont have the $$$ to buy the dry cell one i want yet
09-11-2006, 12:28 PM | #13 | |||
BTW: the engine was leaking oil all over the belts when i got it maybe that might have done something? im sure i cleaned it all up properly all the wheels and belts were properly cleaned out
