Old 22-10-2006, 06:40 PM   #1
CROSFIRKJ
Default 95 KJ Laser & POD Filter
Hi All, New here, been reading through the forums for weeks now.
I Have a 95 KJ Laser Liata LXI
I Am about to install a POD filter to replace the standard Air Box.
Do I need to keep the air flow meter?
Also Could someone please explain how to do it? I've got a pretty good idea so far just want to be sure.
Got a Lukey sports exhaust system on it and im hoping this will let the engine breathe a bit better.
thanks
CROSFIRKJ is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 10:43 PM   #2
VippiN
What a performer!
VippiN's Avatar
Yes, without your AFM you're screwed.
It goes Intake>Pipe>AFM>Pod
You'll need some sort of connector that you can buy from autobarn etc.
Realise that without a heat sheild all your pod is going to do is suck in engine bay hot air which might infact make it worse rather than better.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 09:06 AM   #3
CROSFIRKJ
Thanks Vippen,
I have a customised manifold that comes from the intake near the front wheels and comes up mto a half shroud to direct some cold air onto it, but i will monitor it and see how i go
Old 11-03-2008, 07:19 PM   #4
Paulos_N
Crosfirkj, for your pod filter did you use the tx3 adaptor? if not which one will fit? s.o.s
Paulos_N is offline   Reply With Quote Multi-Quote with this Post
