Old 05-10-2006, 10:19 AM   #1
xespack
Default 1990 laser, elec or mech fuel pump?
Hey all,
Just got a 1990 laser from a family member that am having trouble starting. Can get it started sometimes but then cuts out a few minutes later. It has a kill switch which i'm thinking could be to the fuel pump if it is in fact electric. This might solve the problem. If fuel pump is mechanical then i dont know.
I dont know anything about lasers or small 4's at all for that matter.
What model is a 1990? This one is a carby model, did they come with EFI as well?
Thanks guys,
Aaron
xespack is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2006, 10:57 AM   #2
VippiN
What a performer!
VippiN's Avatar
1990 can actually be two different models.. However the majority were KF Lasers. (Sedan type.) They were still making the KE Laser hatchbacks into 1990 but stopped 1/3 way through.
The 1990 KF Laser GL came as a 1.6L carby engine. The 1990 KF Laser Ghia had optional EFI.
Though in a nutshell: If you're a carby you're mechanical, EFI you're electric.
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2006, 11:59 AM   #3
xespack
Thanks mate,
Well if all carby models are mech then that cancels out my idea of switch to fuel pump.
I can get it running perfect sounding nice for about 2 or 3 mins then it just stops. What could it be? So i know its getting fuel then either the fuel supply is stopping or theres an ignition system problem. Makes it hard to test for though when somtimes it starts fine.
Old 05-10-2006, 02:33 PM   #4
xespack
Got it sorted. The switch did it. Must be wired to fuel cut off on carby or something coz its mech fuel pump.
Its a 4 door hatch so it must be KF then?
thanks for the help,
Aaron
Old 06-10-2006, 06:13 PM   #5
VippiN
What a performer!
VippiN's Avatar
If it's the so called 'bubble shape' then it's a KE. The KF are sedans and although some call them hatchbacks they are technically 'liftbacks'.
