Old 01-10-2006, 11:10 AM   #1
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
Default Calculating flywheel power from rear wheel power (adjusting for drivetrain loss)
Hi Folks,
As the title says, does anyone have any tips for deducing an approximate value for flywheel power from rear wheel power?
My car has made 162rwkw on a dyno. If I allow for the automatic trans, the differential and any other sources of friction, drag, heat etc..... What would an approximate value be for flywheel kilowatts?
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2006, 11:32 AM   #2
XR Martin
XR Martin's Avatar
About 210-220kw. All dynos are different and so are the operators so theres never an accurate figure that can be agreed apon.
But a generally accepted figure is to multiply the rwkw by 1.3 or so to get you flywheel power.
A better guide is actually a 1/4mile, in particular the mph.
2004 BA wagon RTV project.
Old 01-10-2006, 11:44 AM   #3
ratter
ratter's Avatar
I have been told by a guy that owns a engine dyno as well as a chassis dyno, the difference on a late model car is about 22%
Pit Lane Performance
Old 01-10-2006, 09:11 PM   #4
macca_779
Turbine Power
macca_779's Avatar
it tends to work out that rear wheel HP equars Flywheel KW. Not gospel but a good guide.
macca_779 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2006, 11:03 PM   #5
Steffo
LPG > You
Steffo's Avatar
It isn't possible to calculate that accurately. Or anything approaching accurate.
The most general guide would be 18-20% loss manual, 20-22% loss auto, RWD.
However, DynoDynamics Dynamometers (and in general, dynos & operators in this country) don't follow this, as they have silly software that adjusts the readings to what it believes (or is programmed to believe) is correct. That's a pretty poor system, there should never be any correction factor, especially attempting to "adjust" for variables like humidity, air temp, traction.. yadda yadda yadda.
PS- I'm well aware people will attempt to flame me for the above post, and I'm well prepared for it.
Old 01-10-2006, 11:11 PM   #6
Steffo
LPG > You
Steffo's Avatar
Oh, and I can't agree with this more.
Old 02-10-2006, 12:25 AM   #7
Full Spectrum
Only a matter of time.
Full Spectrum's Avatar
I just go 25%
"SOUNDS THAT GO BUMP IN THE NIGHT"
Full Spectrum is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 02:27 AM   #8
Steve
torque is your friend
Steve's Avatar
This has been discussed heaps of times before. You CAN'T calculate drive train loss across the board using a % figure. Each drivetrain will have a fixed kw loss regardless of what engine is powering it. A 25% loss of a 180fwkw engine is 45kw through the drivetrain. Turbocharge that same engine to get a 300fwkw figure and apply the same 25% loss theory and you have a 75kw loss through the very same drivetrain. Impossible.
Support Cystic Fibrosis Australia
Learn about it here, donate and help the research into finding a cure and to provide services for children living with CF and their families.
Steve is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 03:25 AM   #9
XR Martin
XR Martin's Avatar
Friction is not a constant
Old 02-10-2006, 05:03 AM   #10
Full Spectrum
Theres a fraction to much friction
Old 02-10-2006, 06:02 PM   #11
HSVETAR
Bring on the lion...
HSVETAR's Avatar
This is very true. But from what i know and have read, its normally 25% for autos and 20% for manuals.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD
9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile
XC Falcon project car underway......
HSVETAR is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2006, 08:50 PM   #12
Steve
Steve's Avatar
You know I actually heard that song today and thanks to your post I had it freaken stuck in my head for ages. out:
Old 03-10-2006, 07:32 AM   #13
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Were I go to tune,we dont use correction or inertia and dont even use shootout,same operator,same dyno.
We still get varying numbers from one time to another,the biggest difference highest to lowest was over 60hp.
I dont put much faith in em,just tune the car and thats it.
Although they can give a rough guide..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 10:24 AM   #14
Steffo
LPG > You
Steffo's Avatar
Tuning makes sense, yeah, best if done at the same dyno time and time. But as you've said yourself, the variance they give on figures is huge. And that can happen on the same dyno in 5 minute intervals, let alone two different ones on two different days.
The best guide to know how well your car's performing is to take it to the track and give it a run.
If you really want to know how much power your engine has (and can afford it), take it out and send it to a proper engine dyno. Power figures from chassis dyno's are close to useless. Ask any 1000rwhp Supra owner from the US who runs 12.5 @ 135mph about it.... :
