XRSVO
Hello guys recently Ive been getting a heavy fuel smell in the cabin.
Mainly comes from dash vents ,I think I cant tell as smell gets stuck up my nose and it makes me sick very quick! Ive checked the car over and cant find a fault anywhere (nothing obvious anways) a few symptoms are it happens full or empty will do on anything more than 1/3 throttle happens with or with out flash tune my fuel consumption aint good either prob getting 350 to a tank has anyone had a similar experience? or maybe could offer some ideas as its almost undrivable it gets that bad thanks Joel |
AULTD
Mine was leaking from where the fuel pump goes into the plastic tank, apparently the tank can deform.
Petrol would actually leak out when I filled up and you could see a stain down the side of the tank when you looked underneath the car. They put a new tank in under warranty ( around 95 000 k's ) Smell would get into to car when de-accelerating so might be worth a check. You need to take the plate off in the boot to have a look or just look for any tell tale signs of stains on the side of the tank |
XRSVO
I took the plate off the other day and it was dry as a bone around the top of the fuel pump ,but it does have the stains down the side off the tank ! and giving a stab then backing off does it ,so Looks like thats the prob
hmm out of warranty by a few months too any ideas on cost of a replacment? thanks Peterban |
#4 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
hey swoop you mite have to get the pollution canister / system checked out my old car was doing simular thing fumes were bad with a/c on or just the vents open .was the one way valve thingy in the charcol canister it was filling with petrol not sure how the fumes came to be inside the car but a new one fixed it ..Cheers mate .....Whoosha
P.S wares me video :hihi:
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
XRSVO
Tanks whoosha ill check that one out too! might be both tank and what your describing....
ps ![]() also im just plain lazy atm cheers guys |
XRSVO
I dropped it off at the local FD today ,after tank was removed they found the breather tube running to filler neck had been sliced open by the tank squashing it on a spot weld on the chassis
AULTD
Bad luck it was out of warranty.
At least you didn't have to buy a new tank. I hope Ford didn't charge you too much. |
