Old 24-07-2006, 06:12 PM   #1
JUZXR8
Hmmmmm
JUZXR8's Avatar
Default Urgent Help Needed!!!!!!!!!!
ok guys,
funny story really my mate has just locked his keys in his series on EA (non smartlock or central locking) and he need to know how to break in other than jumping on the roof as he has no spare key....help please!!
juz
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 06:17 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
This thread may help:-
http://www.fordforums.com.au/showthr...ht=locked+keys
I am led to believe all e-series doors are virtually the same
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 06:17 PM   #3
John_LS1
bust a window. drivers is easy to change.
Old 24-07-2006, 09:10 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
coat hanger and gouge/pull up the sniper knob usually works, takes a bit of effort.
Old 24-07-2006, 10:01 PM   #5
kosmo652
wire and put fingers in top of door pull out slip wire in and unlock pretty scary how easy it is and how far you can pull top of door out
kosmo652 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:04 PM   #6
needfordspeed
Yup, this would be the best way IMO, takes a little while to get used to it, but it's better than breaking windows etc!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:08 PM   #7
BENT_8
BLUE OVAL INC.
BENT_8's Avatar
When i had my EA i just used packing tape (the plastic strapping) and put a small dob of Blu-tac in the bend, pull open the top of the door(quite easy on E-series, especially over 110km/hr)slide the packing tape down over the lock thing and pull it tight then pull it up.
No scratches that way.
BENT_8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:11 PM   #8
XRated
Shoot.
XRated's Avatar
...and then expect lots of wind-noise! :sm_headba
20V Turbo
Old 24-07-2006, 11:14 PM   #9
DEVL-XR
EBII XR6
DEVL-XR's Avatar
if you'd rather smash a window why not just smash the little window on the rear door, its only little and wont cost much to replace and its really simple to fix too.
thats unless your able to use a coat hanger sumhow.
cheers
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 05:20 PM   #10
JUZXR8
Hmmmmm
JUZXR8's Avatar
cheers
complete opposite dude, they are friggen expensive to get replaced....just the window itself aint cheap
Old 25-07-2006, 05:29 PM   #11
Rmyers
Does Steve have a car?
Rmyers's Avatar
This is the best way. I remember way back when the goodz first got his car and locked himself out. We called RACV and they came over and did the same thing with packing tape. After that we tried it and was easy as ****.
+ 1 vote for packing tape....
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 05:30 PM   #12
Kenster
Kenster's Avatar
I been told that E series could break into each other just with other same car key not sure if it true or not
Kenster is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 12:36 AM   #13
89 S-PACK
my keys open and start dads ea... they also start my sisters ea but i cant open it
but none of their keys will work in mine
89 S-PACK is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 09:34 AM   #14
DEVL-XR
EBII XR6
DEVL-XR's Avatar
of really. my mate had his car broken into through that window and he just went to the wreakers and got one out himself. im not sure exactly how much he paid for it but i know it wasnt too expensive.
he installed it himself too witch would be better than paying someone to do it.
well anyway...
cheers
DEVLXR
Old 26-07-2006, 08:22 PM   #15
Ozfords
Girls! Drink! ****! ****!
Ozfords's Avatar
Isn't that quarter glass simply stuck in?
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy.
1993 ED Fairmont Sedan - I6 - Colbalt Blue
- XH Snorkel
- Superlow Kings Springs and KYB Shocks
- Cross Drilled and Slotted DBA front Discs
- 18" pre-AU GT-P Alloy Wheels
- Ford Original Bootlid Spoiler
Ozfords is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 09:59 PM   #16
Rmyers
Rmyers's Avatar
As is the front and rear windscreen...
AKA Mr Silver
