Old 23-07-2006, 10:07 PM   #1
superroo
You can't stop the signal
superroo's Avatar
Default Who wants a laugh
Check this web site out if you want:
http://www.force-flow.com
The Force Flow 4.0 Powered Intake System is a universal bolt on device that will adapt to any vehicle. Built into a 4 inch diameter aluminium casing, it uses a super high powered motor that drives an impellor to ram air into your intake. It is sold as a complete kit with easy to follow instructions, it can easily be installed by any ‘Do It Yourself” mechanic.
If you had no idea about cars, the way they explain the system you'd believe what they say.
Interesting looking through the whole site though. Especially the dyno results.
Old 23-07-2006, 10:26 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Its possible isn't it though as it's only a little increase in HP.
There is a thread on Ford Forums somewhere that has a link to a video that shows some fellas hooking up a leaf blower to some stock standard vehicles and it increased the horse power by a very significant amount.
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2006, 10:35 PM   #3
superroo
superroo's Avatar
It's possible, but why would you do it though???? it only on at WOT
Their graph show a 7rwhp increase, which when you think that the intake is bigger, it's not that much of a jump at peak horsepower.
Also i seen dyno runs where the same car has varied by that much between runs.
Old 24-07-2006, 01:09 AM   #4
jonk
Oh no ! Not again.
jonk is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 06:18 PM   #5
The G6ET Spot
Have a look at thier warranty and disclaimer that will tell you everything that the product is. A total piece of crap
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 06:20 PM   #6
Casper
Contributing Member
Casper's Avatar
The leaf blower video is on a small 4 cyl and the increase was "minimal". The main increase was when they shot Nitros through the leaf blower into the intake.
These things DO NOT WORK.
Older, wiser, poorer.
Old 24-07-2006, 09:53 PM   #7
RegSpec
RegSpec's Avatar
I can see it now.....
Every man and his dog lined up at CAPA for the latest fad....
: : "DUAL" LEAF BLOWERS" : :
:hihi: :hihi: :hihi: :hihi: :hihi: :hihi: :hihi: :hihi: :hihi:
06' BF XR6T manual sedan in Bionic Blue.....written off 08/15......greatly missed...
New ride....07' RSpec manual Typhoon in Winter White....factory sunroof, Premium sound, Process West intercooler, upsized tubing, valve springs, 1000cc injectors, Delphi intank pump,*modified turbo, 4" dump, 5" cat, dual 2 1/2" Xforce exhaust, Mal Wood Opt 5 clutch, Herrod shifter, Ozrace coilovers with adj. Whiteline bars, 6 spot Brembos,
Edit by Crescent Motorsport.....382rwkws @ 1150nms on E85....
RegSpec is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:16 PM   #8
Phoon Hoon
Might replace the Garret in the Phoon with one of these. Yeah - then I'll replace the ZF with the 4 speed auto that comes with the Omega.
Neo BFII Typhoon... auto, tints, mats, performance exhaust, very happy driver. :1syellow1
Phoon Hoon is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 11:28 PM   #9
Smoked
Burnin Rubber
Smoked's Avatar
A bit like the Hurricane device that you could install in your intake to create "turbulent" air flow which is "denser" and thus better.
I dont think so.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 11:54 PM   #10
xr8man83
Grunt Files
xr8man83's Avatar
Force Flow Voltage Stabilizer
The Force Flow Power Voltage Stabilizer regulates the voltage of the car's electrical system, providing constant voltage at all times. Normally the electrical system's voltage will fluctuate under acceleration resulting in power loss and rough power delivery. The Power Voltage Stabilizer eliminates this voltage fluctuation, providing a constant voltage, thereby smoothing power delivery and optimizing power. Low rpm performance is improved noticeably, with improved response, acceleration, and smoothness. Fuel economy is also improved, especially for city driving conditions.
About Force Flow Voltage Stabilizer:
Improve all electrical component performance
Better Fuel Economy
Increase efficiency of electrical equipment
Can be install in any cars, trucks, and SUV
Improve Audio Sound Quality
Improve Headlights Performance
Improve Spark Plugs / Ignition Performance
Optimize Your Battery Life
gee does your voltage need stabilizing just think how great your headlights will work with this baby
xr8man83 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 08:36 AM   #11
Ruger
Bseries Moderator
Ruger's Avatar
hehe see the show car/race car bit? "coming soon" because they havent been able to make a car go fast from it.
their voltage stabilizer is just a capacitor
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 08:54 AM   #12
triple8nitro
Alternator
LOL, yeah notice how they dont have any suppliers yet, what crap.
Special Vehicles for special people. ing_sm
triple8nitro is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 06:46 PM   #13
chief
FTF Club Moderator
chief's Avatar
Hey Casper where is that thread from mid last year with the fool bragging how he did this to his car and and got 100rwkw or something stupid like that.
Albert Einstein:
Fords in the Park 2010
Old 25-07-2006, 06:53 PM   #14
Casper
Contributing Member
Casper's Avatar
Ahh, the fanology debate. That would be this one!
http://www.fordforums.com.au/showthr...highlight=hoax
Old 25-07-2006, 08:36 PM   #15
BPXR6T
These are for sale on ebay at the moment for about $350. I came across the add when looking for turbos. I think they claim it adds something like 2psi. Who's going to be the first to jam a bank of 5 under the bonnet for 10psi. ;)
Think I'll pass...
Old 25-07-2006, 09:36 PM   #16
thunderoo
Blueprint of Perfection
thunderoo's Avatar
RICE :
HIS
426 RWHP / 1100 NM OF TORQUE 393 CLEVELAND
AFD 2V CYLINDER HEADS
1974 XB COUPE
NO TRACTION AT EASTERN CREEK
HERS
BOSS 260 03 XR8 SEDAN
COLD AIR INTAKE BY PERFORMER SHAKERS
FULL X-FORCE QUAD TIPPED EXHAUST SYSTEM
thunderoo is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 09:49 PM   #17
Jason[98.EL]
Jason[98.EL]'s Avatar
just read the full list of post on that thread what a ripper
jason
[SIGPIC][/SIGPIC]
Old 25-07-2006, 11:36 PM   #18
charles_wif_xf
Purveyor of filth
Mmmm 6 month warranty! Where do I line up to gets me one of these doohickeys.
charles_wif_xf is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 08:10 AM   #19
red_hotxr6
red_hotxr6's Avatar
How much does it cost.?
red_hotxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 08:12 AM   #20
red_hotxr6
red_hotxr6's Avatar
Ok saw it $350.00. Too expensive for too little power.
