Old 24-06-2006, 01:55 PM   #1
$90esky
Hiding in wheel smoke
Default Best Fuel
Hey, I was wondering what was the best fuel to use for a Mk2. Since it is leaded I am currently using those little add-ins with premium unleaded. I was wondering what other people use and what works well? Road and track.
Also there seems to be a little bit of fuel being blown through the exhaust, can anyone help there?
$90esky is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2006, 02:33 PM   #2
T3man
T3man's Avatar
I use the highest octane available at whatever servo I fill up at - then add upper cylinder lube AND octane boost. I double the amount of booster if I can only get 95 instead of the preferred 98. Expensive motoring but at least the motor will last for a good while until I'm ready to rebuild it for unleaded 98 (or LPG).
Fuel down the exhaust? Carby kit maybe ....
Old 24-06-2006, 02:42 PM   #3
mustang
mustang's Avatar
mine runs on straight unleaded
1980 Coupe, Blue, 1.6L, 2" exhaust and extractors.
Oversteer Scares The Passengers , Understeer Scares The Driver
WWW.QLDSTREETSCENE.COM/
mustang is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2006, 11:52 PM   #4
someaussieguy
someaussieguy
someaussieguy's Avatar
I used to use the upper cylinder lube but that got really annoying after a while so i took the head off and got the valves changed so i can use normal fuel just like any modern car. Although i do run premuim through every second or third tank just to clean it out. The vavle conversion only costs about $110 if u take the head on/off urself.
MK2 for the win :p
someaussieguy is offline   Reply With Quote Multi-Quote with this Post
