Old 13-04-2006, 09:42 AM   #1
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
Default Trouble launching pursuit
Hey guys, finally got to the Plex last night and had half a dozen runs.
Was running yoko R spec on rear. 18".
Was not able to beat my PB even though the ute is stronger and had tyres this time.
When I finally managed to control wheelspin, I started getting axle tramp.
13.66 was the best I got last night and 104mph.
Any suggestions, I tried all sorts of methods and still could not match my PB.
Had fun though
Happy Easter
John
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 11:42 AM   #2
Chris
AFF.com.au
give us some increments
Chris is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 11:56 AM   #3
superpursuit83
KITTY Crew Member
Ok wont be long sheet is in carpark
FOR SALE
Old 13-04-2006, 12:04 PM   #4
F6 UTE
Ride the clutch.
That's what I do. I aslo cook mine.......
What were your 60' and half track times?
F6 UTE is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 12:05 PM   #5
superpursuit83
KITTY Crew Member
ET 13.688 (sorry not 13.66)
Speed 103.21mph
Reac T .193
60' 2.236
330' 5.89
660' 8.906
660' speed (132kph)
1000' 11.496
Temp 16 degrees Track temp 23.2 degrees
Humid 64%
Density alt 79.9m
My PB is 13.6? (see sig) on street tyres
But my best 60' time is as above, was running 15psi in yoko ao40? R specs
FOR SALE
Old 13-04-2006, 12:11 PM   #6
F6 UTE
My best 60' was with my Dunlops. 2.1 with 40psi.
You have a small amount of gain to be had by getting the big tank moving better from the line, but 2.2 is respectable in cars like ours, especially manuals with 2 tonne on there back.
Don't forget you have to deal with taller gearing than me, and alot of the 'drag' Pursuits and XR8's run different diff ratios, along with the auto.
Just so you know how hard the manuals are to get good times out of, Nizpro just went the first manual 'T' in 11's @ 11.90 last week with 420rwkw in a manual with 4 link and diff ratio change.
Not easy...
Old 13-04-2006, 12:18 PM   #7
CAMS290
trying to get a leg over
CAMS290's Avatar
Kev-XR8ute on these forums did a 1.79 60' last weekend at the LS1 nationals, but thats all he did before he lunched his gearbox.
A good cluth, diff gears and your times should drop.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 12:20 PM   #8
F6 UTE
Diff gears would help, and great if drag racing is the be-all and end-all about a cars performance.
There has to be a trade off somewhere, whether it be a good drag car, or a comfortable multi purpose ute.
Old 13-04-2006, 01:29 PM   #9
PhantomXR8
Now a FG XR8 in Nitro
PhantomXR8's Avatar
Thumbs up
Speed 103.21mph
Reac T .193
60' 2.236
330' 5.89
660' 8.906
660' speed (132kph)
1000' 11.496
Humid 64%
Density alt 79.9m
I know everyone says the same thing, work on your 60'. Even with completely stock good street rubber you can acheive a 2.0 60'. It's just a matter of discovering the hookup that will take you to the 60' line without wheelspin or a hiccup, around 2000-2500rpm, more on sticky rubber. Dropping that 2 tenths in your 60' should drop your E.T. by 4 tenths, should!
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs
PhantomXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2006, 01:32 PM   #10
superpursuit83
KITTY Crew Member
I do have some more plans very shortly, Ceramic button clutch, 4.11 diff gears, oil pump gears, underdrives and a better airbox. My 60ft time should improve when I get the launch right, and if I do that my mph should get a bit better I suppose.
Also I was on the weighbridge for scrutineering and it came in at 1985kg with my race wheels in the back. Bloody heavy vehicle, but luxury is the trade off eh ?
FOR SALE
Old 13-04-2006, 01:35 PM   #11
superpursuit83
KITTY Crew Member
Originally Posted by F6 UTE
Ride the clutch.
The last time I went down I rode the clutch on one launch and got to 3rd gear before I realised it wasnt wheel spin I was a
Very addictive this drag racing stuff, I KNOW i can do better, so I better keep trying.
FOR SALE
Old 13-04-2006, 01:37 PM   #12
superpursuit83
KITTY Crew Member
Also tried out the Beltronics G meter. Set it up with a rough vehicle weight (in pounds) and it was within .05 seconds most of the night. An interesting bit of gear
FOR SALE
Old 13-04-2006, 01:39 PM   #13
superpursuit83
KITTY Crew Member
Thanks everyone for input. I know this is a very revisited topic, and you are spot on Phantomxr8.
It seems that 3500 with R spec rubber is a bit to much to not wheelspin
FOR SALE
Old 13-04-2006, 01:54 PM   #14
Chris
AFF.com.au
Speed 103.21mph
Reac T .193
60' 2.236
330' 5.89
660' 8.906
660' speed (132kph)
1000' 11.496
Humid 64%
Density alt 79.9m
ok - here's your goal
1.90 13.20 @108.
You will need tyres and a clutch, i recomend extreme.
see ya
Old 13-04-2006, 01:59 PM   #15
superpursuit83
KITTY Crew Member
Thanks Chris, and it does not seem out of reach..... cool
FOR SALE
Old 14-04-2006, 08:34 PM   #16
CAMS290
CAMS290's Avatar
I run 4.11's in my Pursuit auto, and it is still good to drive on the highway, revs are up about 400rpm at 100kph, but its a killer off the line with the 3500 converter, 1.81 60' times.
Cameron
