28-01-2005, 06:22 PM | #1 | ||
Hello,
I had a problem today in my 5 speed EB2 I was in 5th gear at 90km/h, went to put it in 4th & there was nothing there. It wasn't going into ANY gear at all. I pulled over to the side of the road, stopped, gave it a shake to get something & when I put my foot off the clutch it stalled so I must have been in something. I've owned the car for 6 years, & now it's done 270K apart from firewall problems in the past generally very reliable. Could it be a problem with the clutch? or maybe a something worse. Any feedback would be great. Cheers.
1992 EB2 GLi 5 Speed, LSD, ABS, LPG. |
28-01-2005, 06:55 PM | #2 | ||
Could be lots of things.
Is it the first time it's happened? Is the clutch properly adjusted? |
28-01-2005, 07:00 PM | #3 | ||
can you get it into 4th now ? 270 k's if it's the original box, probly be due for a rebuild, or was it still smooth and tight. If so i'd be looking at the clutch.
not much help, sorry. |
28-01-2005, 07:35 PM | #4 | ||
Happened on Tuesday as well. Seems to only happen when it's at least 32C. All gears smooth except 5th starting to crunch a little.
28-01-2005, 09:19 PM | #5 | ||
How old is the oil? I'd replace it, try get some synthetic stuff.
28-01-2005, 10:17 PM | #6 | ||
The oil I'm using is Shell Helix Plus 15W-50.
I changed it about 2,000 kms ago. Is there a better oil anyone would recommend other then Shell. Many thanks.
28-01-2005, 10:25 PM | #7 | |||
AFF's 1st DM.......
im thinking he talking about g/box oil mate.
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
28-01-2005, 10:35 PM | #8 | ||
Yeah good point. It was serviced about 8000 kms ago by Shell.
A stupid question but where do I check the g/box oil?
28-01-2005, 10:39 PM | #9 | |||
AFF's 1st DM.......
Drivers side, feel about 1/2 way up the box you'll find 2 plugs ones a drain (The lower one).
the higher one is the fill point/level.
28-01-2005, 10:50 PM | #10 | ||
Thanks for that. Do I need to put the car up on ramps to do it, like dumping the oil?
28-01-2005, 11:03 PM | #11 | |||
AFF's 1st DM.......
will do to get under the car , better filling it when the cars level tho
28-01-2005, 11:14 PM | #12 | ||
Thanks, gives me something to do tomorrow, hopefully that should solve the problem.
28-01-2005, 11:32 PM | #13 | |||
AFF's 1st DM.......
also try adjusting you clutch cable
28-01-2005, 11:40 PM | #14 | ||
Cool, will do.
