Old 09-08-2005, 06:47 PM   #1
MrAUII
MrAUII's Avatar
Default Driving Lights wired ti Hi Beams
How do i wire a pair of driving lights (the ones in front bars) to the hi beams ? So when the hi beam is activated they come on.
AUII Forte 4.0L - AUSOM3
Audio Visual Incar Entertainment
MrAUII is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2005, 07:01 PM   #2
Laminge
Cuban... nothing like it
Easy
Pay someone to do it for you!
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2005, 07:10 PM   #3
EvilChief
Boost Addict
piece of cake
Old 09-08-2005, 08:12 PM   #4
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Originally Posted by EvilChief
piece of cake
By following the wiring diagram in this post, it would not be legal, at least in QLD! Not sure in other states??
where he shows + input from the light( hi beam +) to the relay, you would need to pass thru a switch and then to the relay. Otherwise, spoton
Old 09-08-2005, 08:15 PM   #5
EvilChief
Boost Addict
hehe details :p, but yes technically correct
Old 09-08-2005, 11:32 PM   #6
JC
JC's Avatar
Actually you can have the switch anywhere in the circuit. Easiest way is to have the switch between high beam feed and relay.
Ford Performance Club ACT
Old 10-08-2005, 12:15 AM   #7
EvilChief
Boost Addict
i would say it doesnt really matter on which line you put it, i personally just dont like the idea of running a cable from headlighst back into cabin and back to relay. If it should shorten out there goes your high beams, if put on battery positive and it shortens you loose a fuse and the foggys wont works but at least the high beams will
Old 10-08-2005, 12:24 AM   #8
JC
JC's Avatar
True, but if you run the wire from the high beam switch or fuse (in the car), then the only wire running the length of the bonnet is the one going to the spotties/foggies.
