20-04-2023, 09:38 PM | #1 | ||
AKA “Asking for a Friend, V2.0”
(Different friend, but also uninsured, his “Sunday car” mint VE Calais - driving it while the locksmiths repaired his work van’s steering lock!) It looks like the offside rail is fine, the nearside maybe pushed down 5-6mm at the end. So he’ll need this (clipped from Dumbtree): Is a Calais bonnet different? What about the headlights? How does the pictured front clip fix to the rails - are there sacrificial spars? Or do the rail ends crush and need sectional repair? Any other comments about stuff that’s a repair “gotcha” from this generation of Commodore, would be appreciated. |
20-04-2023, 10:55 PM | #2 | ||
Sick Puppy
Will end up bring a repair that keeps costing more and more.
There will be lots more to be replaced then it looks. Suddenly makes insurance cheap. If he was insured he would getting a cheque. |
20-04-2023, 11:37 PM | #3 | ||
praek tih kl jo kr
Used to wreck these from home when they were new, (you couldn't buy parts from Holden for the first 18 months ) very easy to drop the whole nose off in 1 hit, pop the bumper off and headlights out and just unbolt the rad support ( Rad support with bar reinforcement, washer bottle etc) the radiator and air con will sit there on the crossmember, the Calais headlights are different from the standard and there are 2 types, 1 has the standard globe the other has the projector, the bonnet mould will fit a standard omega bonnet, grille and front bar are Calais, Statesman type set up.
Looks like a high hit, I would say the rails will be ok. |
3 users like this post: |
20-04-2023, 11:58 PM | #4 | |||
HSV - I just ate one!
5 users like this post: |
21-04-2023, 05:50 AM | #5 | ||
Good info, thanks. These
There’s just a slight misalignment where the NSF guard meets the screen pillar, it’s kicked out maybe 3-4mm if that; why I think the left rail is pushed down just a little. Sounds like bar and lower grille will be the hardest parts to source. Any real differences in radiator/condenser quality across the market (assuming both need replacement)? It’s 2010 by the rego, is that a Series 2? Insurance is a good thing, I think a lot more people are skimping on it now though. This fellow is not a leaner, he’s still paying his way well past when many of us have ceased work - or even life. But, yes, he would have been 100% better off with cover. |
21-04-2023, 09:02 PM | #6 | ||
praek tih kl jo kr
Yeah projector headlight, the guards move heaps when they take a knock to the front, the headlights do it as they push the guards out, rails are pretty low, may have bent the cap on the end of the rail that the red support bolts to, but they are easy replaced.
21-04-2023, 09:54 PM | #7 | ||
2010 should be a VEII, 2009.5my was the changeover
21-04-2023, 11:04 PM | #8 | ||
My wife’s VE got backed into by an SUV. Pushed the LH headlight in about 3 inches, popped the bonnet, and pushed the guard out. Insurance quote was over $7k. There was so much hidden damage. The rails weren’t touched. If they were, they said they would have written it off. I priced up all the bits 2nd hand for under $2k, and this was my backup plan. But in the end, insurance fixed it.
I’d be checking the rails carefully. As soon as any of those pre-formed dimples are folded up, they will want to write it off. Not saying you can’t fix it yourself, but it’s not a simple case of pulling the rails back out if they have been compressed. I saw one at pick & Payless around 2017 that had a compressed rail on one side. The repairer fitted home-made plywood spacers between the rail cap and the radiator support to get it to all align….. anything is possible…. Only needed longer bolts…. |
22-04-2023, 07:13 PM | #9 | ||
I had a deeper look, there probably is a little rail end damage but for now I’ll work with what I can. VIN plate says April 2010, so they’ll be the extra rare Series 2 projector headlights, right?
Any thoughts on why it will crank and start, but not stay running? 265K on the clock, two senior owners. It was already due for chains. |
22-04-2023, 08:52 PM | #10 | ||
praek tih kl jo kr
22-04-2023, 08:54 PM | #11 | ||
My brother in law recently fitted stock style aftermarket projector headlights into his VE2 to replaced crazed & frosted originals. They are comparable in beam spread, light consistency and cutoff, when compared to the near new OEM ones in my wife’s car (VE1 Calais V). Unlike the TYC ones for the FG….. which are crap compared to the OEM ones.
Can’t help you with the V6 though, as I only play with V8 VEs, but it would be worth doing an OBD2 scan to see what code it chucks up. Did the airbags pop? If they did, it might need resetting before it will run. Edit: just read the comment above, and looking at the damage again, I’d say that the intake plumbing is the likely issue. Last edited by commodorenutt; 22-04-2023 at 08:56 PM. Reason: Additional info |
22-04-2023, 08:55 PM | #12 | |||
praek tih kl jo kr
https://www.ebay.com.au/itm/12120976...3ABFBMoP2VhvVh |
22-04-2023, 09:05 PM | #13 | |||
I’d have thought that just put it in a conservation mode, weak throttle response to limp home. No pyrotechnics deployed, there’s an airbag warning light on but I suspect sensor wiring or something. |
22-04-2023, 09:09 PM | #14 | |||
praek tih kl jo kr
23-04-2023, 12:32 AM | #15 | ||
I’m now finding some elements of Mr EL’s comments ringing in. Like the broken intake section which seems to be a SIDI only part, therefore dearer/less common.
Picking up a complete radiator support tomorrow for $200, will see what else pops up. Any spots within striking distance of Sydney are welcome. |
23-04-2023, 02:42 AM | #16 | ||
Ford screwed the Falcon
That dirty engine bay means this is not a mint car.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
23-04-2023, 03:20 AM | #17 | ||
I'd be calling a Holden service agent and asking them if its the series 2 update, theres one niggly little thing that doesnt look right to me...
IIRC VE s1 MY2009.5 saw the SIDI update, but in the engine bay pic its missing the redesigned plastic panel at the base of the windscreen that covered the horn to prevent a problem they were having when the horns got wet. https://carsales.pxcrush.net/carsale...ze=1795%2c1195 https://carsales.pxcrush.net/carsale...ze=1795%2c1195 If you look in the back RH corner of the engine bay beside the brake master cylinder, you'll see what I'm talking about. Funny what you remember when you get the "official" training course.... At a minimum the series 2 got a new shape headlight, grille & bumper cover, radiator support & associated parts I dont think changed a whole lot.
23-04-2023, 05:06 AM | #18 | ||
Argh. Is it a “9.5” update, not a true S2, then? Horns are in the outer corners of the radiator support below headlights. It’s going to be fun assembling enough pieces of a headlight shell to read a part number. Ballasts are not on top of the aluminium reinforcement either, if that makes a difference.
One win from all this, is I’ll now be the shop expert on washer reservoirs. They seem to have the flexible filler tube loose from reservoir on every second car that comes in. Syndrome: The car identifies as mint; their choices are supported both by a therapist and all four road wheels. They hope to one day work with disabled animals in a neurodiverse safe shelter, but for now are hustling as a travel influencer. |
23-04-2023, 10:51 AM | #19 | ||
praek tih kl jo kr
Bonnet
https://www.gumtree.com.au/s-ad/camp...ais/1293772443 Here is someone who is wrecking a few VE's https://www.gumtree.com.au/s-ad/hass...s1-/1310564086 Calais front bar https://www.gumtree.com.au/s-ad/smit...828/1286987387 |
23-04-2023, 10:52 AM | #20 | |||||
I'm thinking so.
Ballasts? what ballasts? The headlights on SWB Commodore variants are all standard halogen bulbs, regardless if projector type or not, IIRC H7 and H9. The only time the VE range got HID headlights was in the statesman/Caprice range, easily identified by a black trapezoidal panel midway along the bottom edge of the headlight lens where the headlight washer unit was mounted. Quote:
And again in english?
2 users like this post: |
23-04-2023, 11:03 AM | #21 | |||
Thank you both. I’d assumed projector lenses meant HID units in these.
STwins was already on the shortlist as were JJ and Oz Car Parts (they’ve made a good bit off me since about 2017). Quote:
Worked out the electric vacuum pump on front of the motor is for brakes and maybe other things. Its plastic elbow got broken. |
23-04-2023, 12:11 PM | #22 | ||
Thailand Specials
We're looking at one of those to see if its suitable to **** off the vacuum pump alternator in mates Land Cruiser so he can move to something with more oomph.
23-04-2023, 12:22 PM | #23 | |||
Someone’s already re-branding them. Do you or Interceptor remember the vacuum connections - was it just pump to reservoir and booster via a one way valve and tee, or is it more involved? Hoping I don’t have to replace some vacuum harness that requires massive dismantling just because of the front elbow being snapped. Will be shonking it with heat shrink for a quick fix. |
23-04-2023, 12:54 PM | #24 | |||
Having said that, VEII wasn't introduced until Sept '10 (MY11 VIN BLxxxxxx). I don't believe that the car pictured is a VEII, it's late VEI (MY10). Dr Terry Last edited by Dr Terry; 23-04-2023 at 01:19 PM. |
23-04-2023, 12:54 PM | #25 | ||
praek tih kl jo kr
If its just the plastic elbow, can you use a Bunnings black poly retic elbow as a replacement, they do a few automotive sizes from what I have seen
https://www.bunnings.com.au/holman-1...elbow_p3120094 |
23-04-2023, 01:00 PM | #26 | |||
23-04-2023, 01:16 PM | #27 | ||
Yes, I’m doing my best to educate. Beemer bloke is lurching from one mishap to another at the moment, though.
It’s a big part of why I was asking about those $180 3-way dash cams last week. It’s funny in a way; I’m really tight/picky about how and what I spend on but still consider certain insurances essential. |
23-04-2023, 01:41 PM | #28 | ||||
Thailand Specials
23-04-2023, 03:32 PM | #29 | |||
praek tih kl jo kr
Was going to look into one of those business blanket insurance that covers you for whatever car you are driving in the event of a accident, but I don't know if it would cover the cars that are parked up? |
23-04-2023, 08:01 PM | #30 | |||
Vague memory from way back when (I havent worked for Holden since the end of 2018) was that the SIDI engines were released mid 2009, I couldnt remember the dates from when the S2 was released but it wasnt all that long afterwards. Unfortunately, I never got involved with the vac pump further than supplying a couple to some local hot rodders
