Old 26-05-2022, 07:23 PM   #1
spiker
Default After market focus headlights
Hi all.
So I need to replace the headlights on my 2013 focus sport because a couple of the guide pins have broken and the globes wont stay in place. Has anyone replaced yours with after market units?
any recomendations would be appreciated.
I foung these has anyone used them? Are they any good?
https://marsperformance.com.au/Black...Focus-LW-12-15
Thanks
spiker is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2022, 09:57 PM   #2
fugleman
fugleman's Avatar
Post Re: After market focus headlights
Hi,
Yes i have used them-that photo on the Mars site is actually my car just after i fitted them!!
for the price they are ok $499 better than stock set.
-the drl's are a bit dim in the daytime and will only come on with parking light switch enabled but ok-(rewired them up to a drl relay to come on with engine.)
projector has a mean cut off and will blind tree possums if you use a bright hid bulb so be weary. Use a top halogen bulb or not too bright hid 6000k
-plastic lens is a bit soft so easily scratches and will craze after about 2 years.
easy to pull apart and fit proper hid projector, and upgrade drl leds -$80 or so for new clear headlight lens available-if your motivated to.
other headlights out there but a lot more expensive.
fugleman is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2022, 06:13 PM   #3
spiker
Default Re: After market focus headlights
Cheers Mate
Thanks
