Past 4 years Ive had a Parkmate reverse mirror installed in ute, It is wired on full time as I use it for mirror due to covered in box on ute.
Its getting tired of working now the upgraded model JB hifi $444 ebay $399 advantage of JB would be warranty IF it had problems... your thoughts please
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
#2 | |||
https://autobarn.com.au/ab/Autobarn-...gaAvdQEALw_wcB https://www.supercheapauto.com.au/p/...PO7454773.html |
I've got this one in my ute as I have a separate dash camera and it's a neat fit as it replaces the standard mirror.
It switches to rear camera view when reverse is selected otherwise it's a normal rear view mirror but it's also wired via a dash rocker switch so reverse view can be completely turned off if needed. I've got 3 camera's on my trays rear bumper, central, right and left side and it can be switched between either or have a central or split view, eg either camera on its own or left and right as a split view etc. Had for approx 6 years and its always been set for on when reversing and I've had no issues whatsoever. http://members.iinet.net.au/~ozrunne...cs/Mirror3.JPG https://www.parkmate.com.au/products...mirror-monitor Last edited by ozrunner; 04-11-2021 at 05:00 PM. |
Thanks Dr,
different model, slightly larger screen and needs original mirror to clip onto. Ozrunner that is what I am after, Can someone advise if the BA/BF mirror mounting is the same as FG
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent Last edited by Tonz; 04-11-2021 at 05:05 PM. |
#5 | |||
nah the monitor has gone blank.
bugga now you got me worried....which is it? I just presumed it would be monitor/mirror.
so went out to have a squizzz and when engine is turned on a 'no signal' appears on the screen, wiring back to camera looks OK.
So how does one test this to find out which item has got on the blink?
I would reckon the camera is the problem,probably the sealant has gone hard and let moisture in
update on old post.
Somehow I got all working but cannot remember how. I now have a box trailer that has a 12v camera fitted, when we went to wire this into the full time reverse camera on the ute, we discovered the ute camera is 3.7v so we have a problem. I have a camera, that works on reverse only that shows the towball and area around, the inside mirror was replaced with a camera mirror that is on full time showing behind ute, So I would like to upgrade with new FLUSH mount 12v camera for ute and another mirror for inside. The latest ones can have a front facing camera as well but they mostly appear as clip overs not the windscreen mount. So recommendations/thoughts/ideas please
