30-01-2021, 09:21 AM | #1 | ||
Hi,
My interior lighting (both back and front) are not working at all.
What are my next steps to debugging troubleshooting this problem? Thanks |
30-01-2021, 11:13 AM | #2 | ||
Regular...with metamusal
fuse working so good there .... if you have a multimeter pull globes & check for resistance or just swap in a 'spare' globe to check. can also use multimeter to check for power at light base.
31-01-2021, 12:08 PM | #3 | ||
31-01-2021, 08:14 PM | #4 | ||
then another way is to pull out the globe/s & use a piece of wire to either apply power/earth to one side & [depending on globe] attach the globes other wire/connection point to the other battery terminal. i have no idea what globe you have.
