Old 07-08-2019, 10:49 AM   #1
kyle88ob
Default k shocks coilovers
so brought some k shock coil over fitted them front went in fine adjusted fine the rear is a spring and a shock seperate so not a true coil over system my problem is the rear bottoms out on the bump stop its not to low its set to same height as from the only thing i car think of is the dampening settings any ideas?
kyle88ob is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2019, 10:57 AM   #2
Default Re: k shocks coilovers
G’day,
What model and spec is it?
Old 07-08-2019, 12:30 PM   #3
kyle88ob
fg falcon xr6 08
Old 09-08-2019, 10:52 AM   #4
kypez
kypez's Avatar
what ride height have you set the car? I'd suggest not going lower than 350mm hub to guard.
My Ford Family...
2014 GT-F, Manual, Kinetic with Black Stripes
2021 Mustang Mach 1, Manual, Velocity Blue
kypez is offline   Reply With Quote Multi-Quote with this Post
