Old 03-04-2018, 02:35 PM   #1
Micky g
Question 71-xy/07-xr6
The quest is to convert the xy using the xr6 donor , has anyone ever tried to Swap the body’s instead of transplanting engine, running gear ,ect ect
Micky g is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2018, 03:22 PM   #2
Vesper Martini
Vesper Martini's Avatar
Default Re: 71-xy/07-xr6
Have you had any experience modifying cars etc?
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2018, 05:46 PM   #3
Micky g
We did a Range Rover 1997 and put a discovery 6 engine in it , bmw 5 turbo , air bag suspension new dash with 7 inch tablet , new loom other bits and pieces . This will be my first xy project
Old 03-04-2018, 05:54 PM   #4
Micky g
Original idea was to put in a Cleveland 302 that was swapped for the twin v that was in the Xy , then with 91/2 diff and c10 Tran but found crack between 2 cylinders on Cleveland and with a xr6 sitting in the shed thought I would try and find out just how hard it would be .
Old 03-04-2018, 06:07 PM   #5
loser5
there is a post where an ef body was put onto a xy frame somewhere have a look for that tthread
loser5 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2018, 06:24 PM   #6
mike_nofx
mike_nofx's Avatar
Hopefully you mean otherway around, otherwise worst conversion ever!
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2018, 10:25 PM   #7
Micky g
To loser5
Thanks mate I’ll have a look 👍
Old 03-04-2018, 10:45 PM   #8
futura
futura's Avatar
Try looking in the Project section. There is an XW Ute with a turbo Barra.
GTF Smoke with Black stripes.
futura is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2018, 12:10 PM   #9
loser5
yes and a fg bottom with a xy top
Old 04-04-2018, 12:11 PM   #10
loser5
street machine were doing the mod and there a video on it
Old 04-04-2018, 12:36 PM   #11
Vesper Martini
Engine swaps are a big enough project... but
The XR6 uses a full monocoque chassis you cannot just fit an XY body to it.
add to that the cars have different dimensions and wheelbases. the only common factor is the Falcon name.
Nice idea but No.
Old 04-04-2018, 03:13 PM   #12
Ford17
Ford17's Avatar
Retrotech XY Falcon with EF falcon running gear:
https://www.streetmachine.com.au/fea...n-running-gear
Ford17 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2018, 04:33 PM   #13
XR.1967
XR 1967
XR.1967's Avatar
https://www.streetmachine.com.au/fea...ch-build-video
XR.1967 is offline   Reply With Quote Multi-Quote with this Post
