Call me dirt... Joe Dirt
I got caught with a flat battery recently.
There were plenty of people willing to assist, but no one had leads. Had to wait an hour for roadside assistance. So now have decided to buy a set and keep in my car. What Amp size is a good general purpose set? Cheers.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
#2 | |||
![]() ![]() Join Date: Jan 2014
You could also consider getting yourself a mini Lithium powered Jumper Starter that fits in the glove box like the one I have, for not much more dollars;
Smart Jump Starter - Fits in Glovebox - Never be left stranded |
![]() Join Date: Oct 2006
regards Blue |
HSV - I just ate one!
get the heaviest set you can find/afford
Dunnydore Destroyer
http://www.supercheapauto.com.au/Pro...Monitor/540712
Get one of these!! I have one and it's brilliant, it will tell you your battery is kaput way before you'll ever need jumper leads. ![]()
______________________________________ "SKIN ON SKIN, LET THE LOVE BEGIN" ![]() |
2 users like this post: |
#7 | |||
#8 | |||
Experienced Member
#9 | |||
![]() That's why I like the FG - FG X i6 engine bays.... No silly engine covers, a modern car but still looks "old school" and simple to work on and get to everything. ![]() |
5 users like this post: |
#10 | |||
#12 | ||
Twice I have tried to start peoples vehicles with their own jumper leads and the engine would not even crank, so then had to get out my own heavy jumper leads and the vehicle started. One guy had just walked 2 miles and purchased a set to start his vehicle and they where total rubbish. SO DON"T BUY THAT CHINISE RUBBISH.
#13 | |||
#14 | |||
Experienced Member
Works every time. Cheers. |
#15 | ||
Cabover nut
Having trucks, I keep a couple of sets of long, heavy jumper leads one at home and one with whatever truck I'm using at the time. You can not go wrong with oversized leads.
Several times I've jump started cars with useless undersized cheap sets which tend to fry. A volt / amp meter is useful as well but I spose they're a rare thing in cars these days.
#16 | ||
Dunnydore Destroyer
It has an App, the tech hungry Millennials should lap this sort of gadget up shouldn't they?
#17 | ||
You are much better off just making your own. Buy some heavy 35 or 50mm battery cable, 4 lugs to suit and a set of heavy alligator clips.
Won't be cheap mind but will last a lifetime. |
#18 | ||
I second that.You can get 70mm cable for maybe $10-12 per metre.6 metres of cable and $30 for some heavy duty clamps and away you go,for not much more than 100 bucks,and they will start anything and last forever.
#19 | |||
Where does one get these from? please....
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
#20 | ||
Different brands but do the same thing... They are available at Supercheap, Autobarn and other Auto stores.
Alternatively, if you want the one I have, here is their website where you can contact them for their resellers in your area; http://smartjumpstarters.com.au |
#21 | |||
jaydee351 4DV8 |
#22 | ||
+1 for the lithium jumper pack. They are unbelievable for the size.
I bought an eBay one for something like $125 from a seller I'd bought a fair bit off before (who has a bricks & mortar business in a regional town) so I figured it would be a decent product). It's been great. I've used it to jump carby V8 Commodores that have been parked for a while, and more recently, a diesel Colorado when it's battery crapped itself overnight when we were on a trip. The stuffed battery couldn't even get the starter solenoid to click. Left the jumper pack connected for about a minute (the little leads got real hot) and it gave enough to slowly crank it over & start up the diesel. I keep it in the boot of the FG. The one I have came with a 240V charger, 12V charger, and an "octopus" of leads to charge a myriad of i-devices. It's all in a neat zipper bag. I've jumped 3 different cars at work - 2 were from leaving lights on (not all modern cars cut them or give warnings), and the 3rd was a stuffed battery - got them going enough to get to supercheap to get a new battery bought & fitted. Don't believe the amp-hour ratings on them. Some claim things like 40,000mAh, but there's 5 8000mAh cells connected in series..... And don't let what you may consider a low capacity put you off - those lithium cells can dump their voltage in a short time - giving the dead battery enough juice to kick over. You won't start a car with one if there's no battery in it - they are used to "top up" the car's battery enough to get it started again. |
#23 | ||
2 4 turning 2 4 burning
Have you considered in buying a new battery!!! People Ike you keep me in a job thanks mate
#24 | ||
Forgot to mention too - having a jumper pack means you don't need to find a willing volunteer to get a jump start from either.
It's harder & harder to find a volunteer as many people fear frying the ECU and other nasty things they've heard stories about. It's extremely rare that it can happen, and usually caused by incorrect polarity, or not knowing where to place the leads - or letting it run with no battery connected, so the alt voltage spirals out of control. |
#25 | |||
It's probably worth mentioning here the correct procedure for using jumper cables. Surprisingly, most people who think they know how to jump-start another car, get it wrong in STEP 4; |
