Old 23-10-2016, 08:38 PM   #1
DrFalconstein
Default 1999 Laser engine stalls
Hi wonder if anyone has had this problem, Ive got a 1999 Laser 1.6 5 speed manual.
When sitting in traffic for a long period of time, or crawling in traffic the engine revs drop and the engine will stop running. and wont re start for about 5 min.
ive replaced the Air flow meter. Its like its not getting enough fresh air, the cars drives great when on the open road.
Cheers Darren
DrFalconstein is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2016, 09:13 PM   #2
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: 1999 Laser engine stalls
Sounds like a sensor is playing up with heat...cam or crank angle sensor or coil pack would be my guess for cause of no spark. You need to check for lack of spark or fuel when the vehicle does not start...
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2017, 09:57 PM   #3
DrFalconstein
Ive just changed the crank angle sensor, car drives great for 30min then starts to splutter under acceleration ! engine running but when you accelerate it has no power then cuts out. starts up after 5 to 10 min
can hear the fuel pump working
I want to solve this problem without it costing, need to sell the car
Thanks
Old 14-02-2017, 12:14 AM   #4
GTLEGEND
Thanks
Just because you can hear the fuel pump working, does not mean it is working correctly and sending the right amount of pressure and volume, especially when more fuel is required such under acceleration and increased loads. I would firstly take off the fuel supply line at the rail and measure the amount of fuel in volume over a certain period of time (would need to look the spec up) and then put a pressure gauge and see what the pressure is when driving and the problem occurs. Blocked fuel filter could also be a cause.
Check these as a first step..
Old 21-02-2017, 05:11 PM   #5
DrFalconstein
ok thanks, it stops mostly when waiting at lights after 30 min of driving.
last drive when it faltered the engine was running whilst rolling but would splutter when accelerating then cuts out altogether
Old 21-02-2017, 08:30 PM   #6
GTLEGEND
Also check if there is spark when the concern occurs, could also be the dizzy module, or other parts of the dizzy.
Old 22-02-2017, 07:32 PM   #7
DrFalconstein
is the fuel filter under the car near the tank ?
Old 23-02-2017, 04:53 PM   #8
GTLEGEND
Carby has a plastic one on the firewall on the passenger side under the charcoal canister.
EFI engines have a metal one basically in the same spot...
