Hi people my 2006 2.0 duro manual lx 4 door hatch out of the blue does and shows nothing when trying to start it all lights windows remote key radio are all working fine try to start it nothing no noises no dash lights no gages hooked it up to a code reader nothing cant reset through the code reader is there a manual way to reset or is it something else.
Any advice welcome cause I have tried everything I know. ![]() |
Very unlikely to be the ECU. You've got a no-crank no-start problem.
Immediately the most likely culprits are the battery (enough voltage to turn on the accessories, but not enough juice to turn the starter motor), bad battery connections (especially the terminals or wiring), or sometimes a faulty starter motor itself. Other problems can include an issue with the ignition system itself, like the starter really, ignition switch or the safety switches (clutch pedal position switch in a manual). If you have a multimeter, start by verify that you have at least >12V at the battery and then work from there. If you don't, the other thing you can try is getting a jump start and seeing if your car cranks when being powered by other battery. |
Battery is showing 12.6 just sitting there, I've never had to depress the clutch to start it before, and yes it is like the battery is disconnected except that all lights work but when key is in the on position no dash lights at all no seat belt or doors open beeper.
#5 | |||
Also, I've been taught to always start the car with the clutch depressed. It takes the transmission load of the engine. |
I have a JUMPER pack I will try it and let you know.
#7 | |||
The problem is it doesn't crank had the ecu out and tested today its fine they are telling me it's the dash because they are programmable.
So next move is a second hand cluster so if anyone has a second one but knows it works I need one. ![]() |
How does a dash cluster stop a car from cranking over? I am curious to know, I did not know this could be the case. Is it an ant-theft thing?
I had thought there was a small chip in the key fob that told the engine management computer it could start the car I wonder if that is broken or the signal not being received
#12 | |||
Where are you located?
Imlachs in Springvale have a few focuses in their wrecking yard
EO XR5 Turbo: PS u412, Deresonated Xforce Catback, 200 cell cat, 3" downpipe, Dreamscience CAI, Airtec Gen 3 IC, Turbosmart dual port, RS injectors, Elevate TCV, VT torque mount, King Springs, Bilstein B8s, Whiteline RARB, Adjustable Camber arms, PDW Oasis, Bonnet strut lifters |
#14 | ||
#15 | ||
Found one problem there's a small cpu that talks to the ecu got a new cluster as cpu had burnt out now it has to be programed to match ecu but can't fine anyone who can do it. BEEN AT 4 AUTO ELECTS FOR 3 MONTHS NEXT STOP SIMS
