Old 15-08-2015, 10:25 PM   #1
ROOSTA
DFDFDF
ROOSTA's Avatar
Default AU V8 Engine Mounts
Hey guys,
After some advice please.. Bought to drop my 220 motor into my car, but am a bit nervous about using the stock engine mounts after all the work it too to remove the snapped off bolts, most likely caused by the ****** factory mounts.. Seems to be a fairly common thing..
So my question is what are, in your knowledgable opinions, the better engine mount options available to me?
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2015, 11:06 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: AU V8 Engine Mounts
Originally Posted by ROOSTA View Post
Hey guys,
Cheers,
Nik
What if if you use the au mount but use higher strength bolts like cap head screws and possibly get them slightly longer so you can put a spacer under the head then if you do happen to snap a bolt head off, you will still have the body sticking out so you can grab it with pliers and undo it.
Cheers.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2015, 06:34 PM   #3
lotus
What car are you putting the 220 into. If you are putting it in the ED just use the E Series v8 mounts. That what I did when I fitted the 220 into my EB.
If I remember I think there was a problem with the plate that bolts onto the block on the AU's. I can remember someone saying the plates can be warped and when tightning them up can put extra pressure on the bolts.
I replaced the bolts when they snapped with high tensile ones and they have snapped as well. Will be pulling out the motor from my AU to do a few things to it and will hopefully be able to removed the broken bolts
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2015, 07:11 PM   #4
ROOSTA
DFDFDF
ROOSTA's Avatar
Thanks guys.. Yer its going into my ED which i have fitted a EF/EL k frame into.. I was really hoping to go with solid rubber mounts rather than the fluid filled EF-AU style but appears I may be stuck with them.. For the moment.. Just dont want to have to go through the snapped bolt scenerio again if i can avoid it..
