I want to run some upper engine cleaner through my old mans fg mk2 ecolpi is this stuff ok with lpg or is it only for petrol engine.
If you saw the state of the throttle body you' self for yourself there has been bad gas going around melbourne there is a lot of black carbon on and oily residue all over the manifold and back side of throttle body and the car has a rough idle now cause of this so we want to clean as best we can.
Should be okay to run (but I'm no mechanic).
Are you gonna get the sea foam stuff or the subaru stuff? |
Performance moderator
![]() Join Date: Feb 2005
Sea foam or some temp [or permanent] water/ meth injection..
#6 | |||
there's also stuff made by liqui-moly and CRC and others but haven't heard of any reports about them so will stick with the subaru stuff. Last edited by Boza; 07-01-2015 at 01:34 PM. |
Thailand Specials
It should be fine, you're supposed to get the engine warm, spray 50% of the can through the vacuum line going into the inlet manifold, let it sit for about 5 minutes, then start the car which it'll cough and splutter and blow white smoke out the exhaust like the Beijing olympics on a carboned up car.
Then when it clears up with the car still idling spray the rest slowly down the intake manifold vacuum line but it might stall so it helps to have someone bringing up the revs. Thats how I've done it anyway, or you can spray the first half of the can in the throttle body with the car off, which also works. But being LPG it probably won't blow much smoke, but give it a crack anyway. Nulon makes one of these products now too, I've used the Subaru and the Nulon stuff. |
#8 | |||
![]() ![]() Join Date: Jun 2006
we use a full synthetic 5w-30 like the book says we use the penrite oil I have heard numerous reports from around melbourne about a particularly oily batch of gas going around something to do with refining process or something like that.
Also heard of a bloke with a nearly new diesel v8 cruiser that filled up at the local safeway where the old man fills up, he filled a full tank of diesel then went home parked the car went to start it the next day and the injector pump and injectors were all rooted from oily-watery diesel 14k of damage the servo coughed up after the fuel was tested. Dunno if it's a coincidence or cost cutting on safeway's part but lately the fuel there is crap and I avoid them like the plague. |
3 users like this post: |
You could get away with using some carby cleaner on your throttle body with the butterfly open and use an old toothbrush to scrub off residue instead of using combustion chamber cleaner.
A dedicated LPG engine like yours will have NO carbon at all on the pistons or combustion chamber.....Thats the beauty of LPG engines....They dont get carbon build up! So really, chamber cleaner is not necassary or required and I doubt wether it will even clean your throttle body properly anyways. Last edited by GASWAGON; 07-01-2015 at 07:09 PM. |
#12 | |||
We put an inspection camera into a e-gas engine that did 150k and it was horrible in there black stuf all over the back of the valves carbon looking deposits on the piston's. I know alot of guy's that run straight gas on there clevo's and are all saying that they have had to pull timing out of there engines and can generally feel the difference in gas these day's and say they are having alot of problem's with oily gas. Apparently since we started selling gas to the Chinese they get the good stuff to keep them happy and we leave the bottom of the barrel stuff for ourselves |
Thailand Specials
eGas Falcons seem to be very sensitive to fuel quality, mate has a BF eGas XR6 ute and you can really tell the difference between one fill to the next, even from the same servo.
Mind you he has been using Caltex servos so that wouldn't surprise me if they sell junk LPG. |
