Hi everyone
In the new year i'm going to be needing a ute that can tow a car trailer carrying a 1.4ton car. I'd like to get peoples opinions on what would suit my needs best. I currently have a XhII xr6 manual which is rated to tow 1.2tons. I was nearly sold on a P250 ute a earlier on in the year but was turned off by the fact your not really ment to tow with it. I'd like to stick with a falcon ute been looking at a few options i'd like to get everyones opinion on what they think is best ?? My options are Bf Xr8 Bf tornado Bf or Fg NA Xr6 OR Maybe and Au 2 or 3 xr8 but i'm a little turned off by a 4spd Auto. I'm open to suggestions. The car will also be my daily (I do about 400k's a week) My other question is some sites say the BF 6 speed manuals are good to tow up to 2.3ton others say they are only good for 1.6ton which is true ?? Thanks for all the advice |
Experienced Member
Most manuals are rated to 1.2/1200Kg's ton because of the clutch where Autos with Heavy duty tow bar will be 2.3 ton/2300Kg's.
Most people will argue that the manual will do great pulling extra weight, I won't argue that but look out the legality side of the law & do your home work carefully. Cheers. |
![]() Join Date: Jan 2005
I use a FG2 EcoLPi to tow my XR8 and trailer (2300kg all up). Pretty much every 6 cylinder will tow 2300kg. Just get a trans cooler and a Hayman Reece tow bar will give you the 2300 kgs for a good price (From Ford, they are very expensive as they have load levelling as part of the kit).
Not sure on the BF XR8 though. Should be the same. Its only the FPV's that had reduced towing rating to 1600 for their Auto.
My Ford Family... 2014 GT-F, Manual, Kinetic with Black Stripes 2021 Mustang Mach 1, Manual, Velocity Blue |
AU wagoon on gas,big trans cooler,H-R towbar.Its like a ute, but with a lockable canopy!
I'd consider a good condition BF Fairmont Ghia or Fairlane with the 5.4 3v. Will pull better than any of the above options and most likely use less gas doing so. Under rated engines that come into their own with some weight behind them.
I have a BF II RTV auto on dedicated gas that comfortably pulls 2300KG, very stable although possibly a little underpowered if you a in a hurry. The petrol one would do better with a few extra KW.
Regards, Tote
Go Home, Your Igloo is on Fire.... |
A Ranger diesel would be far more suitable than Falcon ute. Mate was towing his very light race car with bf ute and said it was scary tail happy compared to his cruiser wagon. Wouldn't use it again.
I suggest a Ranger style vehicle after a mate went from F250s to a Ranger to tow his Mustang in an enclosed trailer. Gets 10.3 litres per hundred towing. |
#8 | |||
7 users like this post: |
Exactly. I can sit at 100 kms/hr comfortably towing 2300 kg in the falcon. Sounds to me that the guy didn't have enough weight towards the front of the trailer.
Experienced Member
Depends on how much weight is in the *** end of the ute when towing a heavy trailer, can be dangerous if tub is empty even if your trailer weight is correct, this happened to me once when towing a caravan.
how often will you be towing ??? if its only now and again,,just hire a toe car when needed
#12 | ||
Ah right. Guess it might be a little different with a Ute vs Falcon sedan.
#13 | |||
I wouldn't really consider a ranger or any other ute other than maybe a commodore. I work for mazda and drive new and old BT-50s (pretty much an ugly ranger) every day while they have loads of torque and I think they'd make a great tow car I still want a car that's fun to drive when unloaded and handles well. I'm not taking anything away from the ranger I think they're great ute just not really my thing. It seems like a lot of people are having good results towing with and egas falcon this might seem like a more economical as it will also be my daily. I would miss out on v8 fun but ![]() |
#14 | ||
A quick question, not sure if this is in the right place to ask. But how do you know if your car was fitted with the heavy duty towing pack? Is there a placard of some sort? Something to look out for? Cheers sorry not trying to hijack.
#15 | ||
The way that I tell is usually look at the compliance plate on the towbar. It will have a weight rating stamped on it. My Xh xr6 has the heavy duty tow bar but is limited by the manual transmission.
#16 | ||
I will have to have a good look then, from memory mine ran through the rear bumper, thanks!!
#17 | ||
Experienced Member
As mention it will be stamped somewhere on the tow bar or you can tell by the different goose neck used on tow bars, bolt on type usually are 1200kgs or 1600Kgs & the box tube type is held in by pin 23000Kg's
#18 | ||
Well you have answered that! It definitely isn't shs piece! Bummer! Thanks for that tho
#19 | ||
You will also need to have a compliance sticker usually on the drivers side door jam area (b pillar).
#20 | ||
I use an XG Manual once in a while to tow a Falcon. XG is technically not rated to 2300 like the later ones but does it fine.
Your XH will do it all day long easily, they are ideal for it. Just load it correctly and you are laughing. If you can go to a larger commercial type vehicle like a ranger or 4wd wagon that would be better but the XH will do it fine. |
#21 | ||
Yeah found my sticker, its blue and does state the rated tow capacity of 1600kg. Thanks for the input and again sorry for asking if its the wrong place!
#22 | ||
From the Futura
Would a territory do a better job, that's getting heavy for a falcon?
1979 Ford Thunderbird Heritage Edition (See Here!)
#23 | ||
Buy a turbo territory, I know you want a ute but theses do an excellent job, I have a ba xr8 witch tows ok, with a 67 xr on trailer but my wife's territory does it much better, just need a lil more power which I why I suggest a turbo, yes it may be a lil thirsty but they are the in my option the greatest all round car,
And a TT ghia are quite cheap now a days for an 06,07 model can be had quite cheap with reasonable Klms too
the wife, 2010 territory, 6sp AWD with 20s EL XR8 daily 67 XR fairmont, the toy!! |
#24 | ||
Experienced Member
I use to tow my jayco 18' caravan 1.8 ton quite well with FG XR6 Auto ute N/A with no problems, the I6 engine is a strong donk & did the job quite well with reasonable economy & I usually sat on the posted road speeds.
For towing give me an auto any day as manuals are PIA. Only reason I got rid of the ute it was useless for my off road purposes otherwise I would still have it. |
#25 | |||
#26 | |||
Former BTIKD
![]() Join Date: Mar 2005
2 users like this post: |
#27 | |||
Two turning.. two burning
It comes down to correct weight on the tow ball and trailer loading. If the ute is overall slightly heavier than the sedan equivalent, and the front, engine bay, and drivers row of seats are identical... tell me how the back can be lighter than a sedan? I know they are sightly longer wheel base, but I think you find the F/R weight distribution will be very similar. That whole light in the back thing was perhaps more true in the xy days..
I LIKE BLOWERS, TURBO'S.. AND ENGINES BIG ENOUGH NOT TO NEED EITHER ![]() BLOWN, 2013 FPV GS UTE TURBO TERRITORY GHIA 545ci XB GS UTE Daily, 2006 F250 crew cab BA2 Fairmont Ghia |
#28 | |||
#29 | ||
Well that's a good point, and I think it use to be the case, but now, it always concerns me when we have all these "plastic" utes, all trying to out do each other, all rated to tow maximum 3.5 ton towing capacity... Yeh that's all well and good in a straight line.. But try and avoid an object on the road, or an accident.. And the weight of the trailer will just take over and flip the tow car, run it off the road etc.
Not to mention that at that kind of maximum weight, the trailer would have to be very carefully loaded and properly secured... Which often they are not.
#30 | ||
Just kickin' up dust
The way a car will tow a load is VERY dependant on how the load is loaded. It is also dependant on what the tow car is, alot to do with the weight of the tow car. My BA Xr8 ute has towed loaded car trailers many of times and i'm just about to load it up again with a mates V8 wb holden to bring it up from gippsland. Taking the extra time to ensure that the ute is sitting at the perfect point on the trailer to load the tow bar with the ideal weight and having the car straight on the trailer will make a big difference to how straight it will sit on the highway. making sure it's sitting right on the trailer will make the difference from it pushing you around to towing well.
Whatever car you decide with on your list will be good. If you want a fun car to drive and occasionally tow a load, you couldn't go far wrong with what you mentioned. The only thing I was thinking was that I was under the impression the turbo's are not rated to tow well as the extra CONSTANT load on the turbo and engine might run things too hot, as in producing hight boost for too long, Someone who knows alot about the turbo motors might want to clear that up. Cheers
2004 BA Mk2 XR8 ute, Black, 6 Speed Manual, Herrod Cams, Straight through pipes, BF XR 18's, Alloy 5 Post Bull Bar, Stainless Skirts with 22 LEDS, Lots of Spotties and a Golf Ball for a shifter knob ![]() 2 Time Australian National Circlework Champion 2014 & 2017 First Falcon to win the National Circlework Title! Click here First Muppet to win the National Circlework Title Twice! Click here 3rd 2015 18th 2016 2nd 2018
1st Bendigo Bute Ute show Circlework 2015, 2016 and 2017 |
