Old 30-10-2014, 05:40 PM   #1
ooochester
ooochester's Avatar
Lightbulb making an au gocart
hey guys I have always wanted to do this now I have the chance I am making a go cart with au falcon running gear just want to know what I have to keep so the motor will run and drive I have the motor out gear box out and full wiring loom and computer out but I am not shore what I need to make it run any help would be awesome thanks
ooochester is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2014, 10:20 PM   #2
dom_105
Default Re: making an au gocart
No idea, but it sounds very interesting.
dom_105 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2014, 01:07 AM   #3
malazn mafia
Boss 335
malazn mafia's Avatar
BA XR6T Go-kart would be delicious.. But I think a dune buggy chassis would be more fitting. The 4.0L motor is huge, looks like a train engine when dumped on the ground.
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2014, 11:53 AM   #4
noddy383
noddy383's Avatar
How big are you planning on making the cart? The little go-cart with lawn-mower engines fly, but one with 4 of the best litres in Australia would be a hell of a things to see. Some friends of mine used to race a buggy with a 4-cylinder VW engine that would beat SS commodores off the line, so an AU powered one should demolish any competition. I'm keen to see the results.
noddy383 is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2014, 11:59 AM   #5
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I would go Carb not EFI and do not use the VCT version as you will need the ECU to control it.
The lighter a Go Kart is the faster it will go
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2014, 01:43 PM   #6
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
you'll need maf sensor and probably lamda sensor too.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2014, 01:53 PM   #7
ooochester
ooochester's Avatar
ok so i have the full loom out of the car and i can have the ecu i braught the car for a couple hundred had good motor and running gear most of the pannels were bugged and inside smells like am ash tray so was good buy for a project and as for size i think it will be about 800mm shorter then the au orignal size so the tail sharft isnt to short hopeforly it works so do i need any of the abs or any un needed **** ( just engine loom ??
i still want the instrament cluster and brake boster
can this all work
