Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 11-10-2014, 08:40 PM   #1
g6eturbosam
2011 FORD FOCUS LW TREND
Default Possible Suspension Upgrade
Hi Guys,
I have ordered the following for my 2009 FG XR6 Turbo:
Brembo 6/4 setup
DBA T3 rotors
braided lines
19 inch Dark Argents 245 35 19
My insurance would only insure me if I purchased items that could be ordered from factory.
Since I have 110k I was thinking that I would need to upgrade the bushes and coilovers.
Could you possible advise which parts would need upgrading and whether you can install everything. If I do it my self, would I need a total alignment done?
regards
Sam
Sent from my iPhone using Tapatalk
g6eturbosam is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2014, 11:39 AM   #2
Amin
Default Re: Possible Suspension Upgrade
Hi Sam,
You have to drop the entire rear end suspension if you want to change all of the bushes there. Definitely not an easy job and it requires a hoist and a hydraulic press. The diff bushes are the main ones to consider as they are the first ones to let go which also is a very common issue with these Falcons. You definitely need an alignment done if you put on new tyres and coilovers.
cheers
Amin is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2014, 11:51 AM   #3
g6eturbosam
hi amin,
If I do just the bushes are the diff, Do I need an alignment done?
Old 12-10-2014, 12:08 PM   #4
Amin
You don't need an alignment for the diff bushes.
Old 12-10-2014, 12:10 PM   #5
g6eturbosam
cool must do when the brakes are done.
Old 12-10-2014, 12:27 PM   #6
Amin
I suggest you to inspect all of the front and rear bushes and replace them if necessary... Some of the bushes might be stuffed after 110ks. If you are planing to replace the diff bushes, you may want to replace the rest of the rear end bushes while the cradle is down in order to save time and money... Also check for oil leak from the diff itself. You can also sort the diff leakage while the cradle is down.
Old 12-10-2014, 12:46 PM   #7
g6eturbosam
yep good idea. who should I get to do it?
Old 22-10-2014, 01:45 AM   #8
g6eturbosam
ok I have got the upper control and swaybar bushes as recommended by a few suspension places.
Brembos and bushes going in saturday
