Hi I just bought a XR5 2010, on two occasion while driving the ABS and DSC light came on and also in the information display the trip odo and trip meter read all zeros, all stayed like that till I turned of and started it again. Any ideas
Yep..its a wheel bearing issue - the bearing has moved in the hub and the sensor is thinking the car is out of control. Issue wont go away. Fix is new hub generally
LV MKII Focus XR5 - no mods yet! |
Thanks I will let you know how I go
#4 | |||
just some of the common faults that can cause this are: a faulty wheel bearing incorrect tyre pressures heavily worn tyres on one axle and not so worn tyres on another chaffed wiring ABS sensor starting to die Crud build up in the trigger ring for the ABS sensor Dirty MAF sensor Boost control solenoid starting to give up - replace with the metal Elevate item. Have it diagnosed properly by a workshop before spending out money on parts from a forum diagnosis.
Advertising removed. |
