Old 28-04-2014, 12:53 PM   #1
bergr01
Unhappy Power steering issue - help!
hi,
My wife and I have a 2008 Ford Mondeo TDCI, with about 68,000km on the odometer. It's been regularly serviced (mostly at Ford service centers). In recent times it has acquired a really bad habit of locking up the steering wheel when driving at low speeds (e.g. when parking in the driveway or driving out of the parking lot at a supermarket). I mentioned this when servicing the car last time at Courtney & Patterson Ford in Heidelberg... they mentioned something about 'maybe this is an issue with a power steering pump, but we're not sure, but it'd cost $1000+ to get the pump replaced and even then we're not guaranteed it'd solve your issue'.
Was wondering if anyone had any suggestions/recommendations on how to approach this... does this sound like a common/known issue?
(Power steering fluid levels seem to be fine. When my father-in-law and I inspected the fusebox in the car, we noticed that some fuse related to power steering - as per Mondeo manual - didn't even seem to be installed).
Thanks in advance,
Greg
bergr01 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 04:13 PM   #2
Wombat John
Wombat John's Avatar
Default Re: Power steering issue - help!
My guess would also be the power steering pump. Especially if you put it in neutral and rev the engine, and the steering works better.
Wombat John is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 08:17 PM   #3
furiousgibbon
Is it notchy in the centre, worse on cold mornings and gets better when the car is warm or ambient temperature is higher? If so it's sticky valves in the rack. Happened on my 07 Focus XR5, I put up with it for 3 winters and then sold it to a friend (told him the rack would need to be rebuilt though). I've seen costs anywhere between $500 and $900, and whatever you do don't take it to Pedders.
furiousgibbon is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 08:56 PM   #4
bergr01
I'm pretty sure I've had it happen on warm afternoons, after 20+ kms of driving from my parents place, when pulling into my driveway...
and sorry, but what do you mean by 'notchy'?
Old 28-04-2014, 09:08 PM   #5
Superoo
Mondeo TDCi / BA XR6T
Superoo's Avatar
If by locking up you mean that you basically lose the power steering (steering becomes really heavy on an intermittent basis) then you may have a rack/pump problem. I've had my rack and pump changed to overcome this issue. There is a huge thread on rack/pump problems in the Mondeo over at the talkford forums in the UK. It's a known issue. The theory seems to be that seals in the rack break down and cause intermittent blockages in the pump. Have you experienced any light knocking or thud sounds from the steering?
03 Mercury Silver XR6T
07 Blue Ambition Mondeo TDCi Hatch
Superoo is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2014, 09:17 PM   #6
bergr01
I don't recall hearing any knocking or thud sounds. Thanks for the UK forum reference, will do some digging there. Is replacement of a rack/pump a costly exercise? Is it something I need to stick with Ford service centers for? The car is a few years out of warranty now...
Old 28-04-2014, 09:25 PM   #7
furiousgibbon
I mean notchy as in the steering feels like it gets stuck in the centre, and takes a good amount of force to push it off centre. When it does it happens with a dull thud. It may not be what's happening to yours.
Here's an example video: https://www.youtube.com/watch?v=nlMF8zU9YaA
Old 28-04-2014, 09:55 PM   #8
Superoo
Superoo's Avatar
Unfortunately it is costly. My understanding is that the rack replacement is more than what you've been quoted for the pump but that was from a Ford dealer. Hopefully your diagnosis will be something else.
