Old 13-10-2013, 09:55 AM   #1
Ianramsey
Default Escort mk2 1.6 struts to 2.0 struts
Hi guys this is my first post
Ive bought a 1980 1.6 mk2 escort panel van which has got rego but 1 of the struts needs replacing.
Ive been given a pair of struts with springs fitted off a mk2 2.0 escort.
Would these fit straight on for a cheap fix or is there more work involved?
Thanks
Ian
Ianramsey is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2013, 06:55 PM   #2
JimStone
Default Re: Escort mk2 1.6 struts to 2.0 struts
Bolt in, jest check size of top mount. 2.0 springs will be stronger to compensate for heavier engine so front may sit a little higher
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2013, 11:19 PM   #3
Ianramsey
Thanks i thought it may sit slightly higher.
If i wanted to lower it could i put 2.0 lowering springs on? Im thinking i would need very low springs to make a difference.
Old 17-10-2013, 12:26 AM   #4
JimStone
Lower springs will do the trick
