Old 27-07-2013, 02:04 PM   #1
guscorty
Default Maintenance between meetings
Hi Everyone,
As I'm relatively new to drag racing, how often should you change oil and fuel. I once heard that you should change it every race meeting. If I have 3 or 4 runs at a meeting then do say 150 ks and then go to the next meeting, should I be changing the oil and fuel or should it be ok to run the same oil. As to the fuel, how long can I leave it in the tank before it would affect the performance of the car.
guscorty is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2013, 02:07 PM   #2
ratter
ratter's Avatar
Default Re: Maintenance between meetings
maintenance is normally dependent on the power output and rpm used etc, some classes with high revving engines will be checking valve spring pressure and clearances between actual races while some class's require very little, fresh oil is always a great idea
Pit Lane Performance
Old 27-07-2013, 04:37 PM   #3
prasac
prasac's Avatar
just check all oils before each meet and replace if needed. there is no rule of thumb every single combo is different and they all cop different types of abuse.
for instance we make 1200hp DOHC TT V8, rev over 8000rpm and change oils when needed, usually 3-5 meetings. apart from that absolutely no maintenance in between apart from usual fuel n water
the old 500hp 302W NA combo was pretty much the same, every few meetings, it was raced fortnightly revved to 8700rpm and rockers were checked once every so often
pump fuel you don't really want to let it sit for 3 months or more. race fuels, try under a year.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 01:41 PM   #4
guscorty
Thanks for replies guys.
Old 30-07-2013, 06:24 PM   #5
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Hey what drive line combo are you using, type of fuel, oil, etc?
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2013, 01:44 PM   #6
guscorty
Motor is a 302 Clevo with C4 and 9 inch. Car runs 12.6. I use the Penrite HPR 30 for Engine and BP 98 for fuel.
Old 03-08-2013, 11:52 AM   #7
prasac
prasac's Avatar
ur using a decent oil, don't stress too much. drag racing is not rocket science, if you check and stay on top of things before/after each meet all will be good. just go out and have some funs
