Old 25-02-2013, 12:08 PM   #1
dogphlap
Smile Fixed: Unable To Select Gears Fiesta 2004
Hi,
A neighbour could not select any gears in her automatic Fiesta.
I had a look at it last night but failed to find the problem.
Early this morning a tow truck was called.
The tow truck driver knew what the problem was immediately and showed her how to do a temp. fix with a cable tie. He would not take any money. Nice bloke. Said it was a common problem (not a mention of it on the Internet though).
I took a photo of the linkage that had disconnected.
The mechanical connection appears to be to a lever that rotates a select shaft (through a few tens of degrees) that sticks out of the gear box. The originating end of that linkage being from the drivers gear select lever. Please correct me if I got anything wrong here (I know nothing of Fiestas).
Blindingly obvious when it is pointed out to you.
Best regards
dogphlap is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2013, 01:24 PM   #2
Pursya
Default Re: Fixed: Unable To Select Gears Fiesta 2004
Geez those cable ties are a great invention!
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2015, 04:37 PM   #3
Wedding Singer
Yes just had the same problem with the daughters fiesta......
Wedding Singer is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2015, 02:11 PM   #4
DRU842
Tis the season for this failure. Our 2006 Fiesta has just gone down with the same symptoms, except our is the manual.
2017 Mustang Lightening Blue, Cobb Intercooler, CAI, AccessPort, Turbo Blanket & V2 Exhaust, Mishimoto Down-Pipe & Overflow Tank, GFB DV+, Custom CRD Tune. Ford Performance Short Throw Shifter & Strut Brace. DBA T3 Brakes & Pads. Braided Brake Lines. H&R Coilovers. Anderson CF Track Pack Spoiler & Tailgate Panel. Blue CF/Leather Steering Wheel.
DRU842 is offline   Reply With Quote Multi-Quote with this Post
