Old 10-09-2012, 05:33 PM   #1
Carlo89
Default Slotted or Blank Brembo Rotors
Hey Guys,
Driving a BA F6 Typhoon. Long story short, need the rear rotors replaced. Originally they are running drilled brembo rotors. I have had a look and found replacement drilled Brembo rotors are crazy expensive. Would I be disadvantaging my self if i were to save a bit of cash and replace the drilled rotors with blank rotors? Will I find myself losing performance?
Any help would be great.
Carlo89 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 05:36 PM   #2
The Yeti
The Yeti's Avatar
Default Re: Slotted or Blank Brembo Rotors
For street driving no I doubt there will be any noticable difference
Except it will look odd through the wheels for the front to be slotted / drilled and the rear to be flat
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 05:51 PM   #3
marcyeo
Regular member
marcyeo's Avatar
I believe that as the rotors/pads heat up with use they create gas. The slotted rotors allow for the gas to be dispersed when the pads clamp down on the rotors therefore keeping the rotors cooler and allowing better braking by preventing gas buildup. The sponsors from Racebrakes should be able to explain it a bit better.. I wouldn't compromise safety or performance for $ savings..
CURRENT
2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance.
OLD
2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw
marcyeo is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 06:11 PM   #4
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
Ring Auto wholesale Australia in Nth Coburg Vic 03 9354 2962 and be pleasantly suprised, I know they have fronts last time I rang they were working on the rears that was 12 months + ago.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 06:14 PM   #5
mike_nofx
mike_nofx's Avatar
Can't machine the rotors?
Depending on how you drive of course, but Rear rotors should last a pretty long time!
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 08:11 PM   #6
FG50T
FG50T's Avatar
You wont notice a performance difference on the rears.
FG50T is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2012, 08:52 PM   #7
J.C.
Ebay.
J.C. is offline   Reply With Quote Multi-Quote with this Post
