Old 24-07-2012, 11:52 PM   #1
manamp27
Default 2011 Titanium hatch annoyances
I have had the car for 4 months and love it. It's the 2 litre diesel power shift auto. I do have a couple of things that are annoying me though:
1) The door rubbers make a hell of a lot of noise as they rub against the body of the car. The car seems to have a lot of body flex and, when I drive slowly over an uneven surface, the door rubbers squeak against the door frame. I have tried some silicone spray but this only mildly fixes the issue for a few days.
2) The trim around the gear shift does not secure very well and has a habit of lifting out of place. It should clip and lock into place, but it doesn't. In addition, it makes a constant stick/unstick noise as I am driving along. I have had it replaced by Ford but the new one is no different.
Anyone had these issues and can suggest solutions?
manamp27 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 02:04 PM   #2
apstar
apstar's Avatar
Default Re: 2011 Titanium hatch annoyances
Shouldn't this be covered by warranty if you only had it for 4 months?
apstar
apstar is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 03:44 PM   #3
manamp27
apstar
Service dept didn't want to know about the noisy door seals ("they're all like that"). And I am not keen on having them replace the door seals in case they screw something else up.
Anyway, I've done more research online and this appears to be a quite common problem. Not just for mondeo owners, but also other marques incl BMW.
Some get the door seals replaced and it works half the time. Others have used a product called Gummi Pflege Stick which fixes the prob for anywhere up to a year.
Think I'll try this first.
On the second item, I think I'll push this further with ford. It's possible the trim piece is not the issue, but rather the housing it needs to clip into.
Cheers.
Old 25-07-2012, 08:44 PM   #4
ope126
ope126's Avatar
Cheers.
I have been using Einszett Gummi Pfledge (made in Germany) for a few years now with great results. I have used this on many cars and works a treat on all.
Highly recommended!!!
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2012, 09:38 AM   #5
allanv6gt
Tippy-tronic Free Zone
Seems to be a standard response in some dealerships (e.g. my own brakes issue).
My 2010 XR5 hatch is silent, no door squeaks whatsoever.
If the cover plate is popping out all the time, then (as you suuggested) the console is maybe not fitted properly. Could be under tension, then with some body flex (which all cars do, the degree just varies), the cover plate pops out again. This is a WARRANTY ISSUE.
Old 27-07-2012, 11:02 AM   #6
Dusty1
Giddy up!
Dusty1's Avatar
I had flexing noise on my MA, mainly going up driveways at a slow speed.
I took it to the dealer and tightened up the rear suspension and that sorted some of the noises in the rear.
I just think it's how it is. Not perfect, nor acceptable to many of us, but that's cars.
Current:
June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint.
Nov 10 built XR6 Sensation.
Previous:
Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof.
Dusty1 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 02:20 AM   #7
NZ XR6
I've had 2 Mk 4 Mondeos and neither has ever made any noise from the door seals. And both have been driven in quarries over some pretty rough terrain, so if your dealer won't fix it, I'd get on to Ford.
The first one had some squeaks from the centre console and that plate was a little loose, but never popped out.
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels.
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2012, 10:18 PM   #8
manamp27
I hate giving my car to the dealership unless absolutely necessary. So here's the update:
1) Gummi Pfledge on order for the noisy door seals. I'll report back once I have applied it.
2) I managed to resolve the noisy trim piece. I used some adhesive felt to force a tighter fit and all fixed now.
2011 Mondeo Titanium Hatch, TDCI
Old 18-08-2012, 08:25 PM   #9
manamp27
Thanks for all your replies.
Have now applied the Gummi Pfledge and pleased to report that 95% of the noise is gone. Highly recommend this product.
Old 18-08-2012, 09:22 PM   #10
ope126
ope126's Avatar
Gummi Pfledge FTW!!!
Another great German part that actually WORKS!!!
Old 28-09-2014, 05:24 PM   #11
ope126
ope126's Avatar
I just used the Gummi Pflege on the Titanium and it makes such a dirfference!!!
Old 29-10-2014, 11:30 PM   #12
mik
mik's Avatar
i like the look of this Gummi Pflege, would local car accessories stores have this, ie, repco, bursons, autobarn, etc,etc ???
Old 29-10-2014, 11:44 PM   #13
ope126
ope126's Avatar
Here you go; http://www.waxit.com.au/
or eBay. I don't think it is available from the stores you listed.
Old 30-10-2014, 12:53 PM   #14
mik
mik's Avatar
goodo thanks mate !
Old 30-10-2014, 07:44 PM   #15
Binny
I have both the problems the OP had on my 2011 as well. I'll have to get me some of that Gummi Pflege. It sounds the goods.
Thanks for the tips!
Binny is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2014, 09:54 AM   #16
rxj
rxj's Avatar
Just used the Gummi Pfledge on the door seals of my Mondeo and the noise around my drivers side door has disappeared. An excellent product.
Cheers,
rxj
1997 EL Fairmont
2003 BA Fairmont Ghia v8
2007 BF FPV F6 Typhoon R-Spec
2008 FG G6E Turbo
2009 SY II Territory Ghia AWD
2012 MC Mondeo Titanium Ecoboost
2018 MD Mondeo Titanium Ecoboost (Current)
rxj is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2014, 07:39 AM   #17
GK
Walking with God
GK's Avatar
Cheers,
rxj
Where did you get it?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 29-12-2014, 08:24 AM   #18
Binny
I got it from the waxit website quoted above. Had it within 48hrs.
2016 Kuga Trend TDCi
Old 29-12-2014, 10:27 PM   #19
GK
Walking with God
GK's Avatar
Cheers Binny, but what section of the site is the product in?
GK
Now gone!
On LPG
Old 30-12-2014, 08:15 AM   #20
XAVEE8
XAVEE8's Avatar
Here you go GK... Both links are forum sponsors
http://www.waxit.com.au/collections/...i-pflege-stick
https://www.carcareproducts.com.au/p..._gumme_pfledge
XAVEE8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2014, 02:47 PM   #21
GK
Walking with God
GK's Avatar
Thumbs up Re: 2011 Titanium hatch annoyances
Originally Posted by XAVEE8 View Post
Nicely done! Many thanks.
GK
Now gone!
On LPG
