30-04-2012, 10:19 PM | #1 | ||
Anyone know for certain if series 1 door lock actuators are the same or different to series 2 and beyond?
01-05-2012, 06:37 PM | #2 | ||
Go into ebay, there are usually a few for sale and the sellers list the difference.
http://www.ebay.com.au/sch/i.html?_f...All-Categories |
01-05-2012, 06:39 PM | #3 | ||
Lost Boost Gained Class
series1 au are Different to series2/3 They will not work (wireing layout)
hope it helps
2006 BF Fairmont Ghia
2001 AU Falcon |
06-05-2012, 12:33 AM | #4 | ||
Looking at Ebay, none seem to be listed specifically for the Series 1, some even say they all fit.
Do the series 1 have the white plug? |
06-05-2012, 12:35 AM | #5 | ||
I ♥ EDM
Interesting.
I have a fully functioning AU2 actuator in my AU1.... |
06-05-2012, 06:40 AM | #6 | ||
Just replaced one of mine from the the wreckers out of a ba hooked straight up only difference was the steel rod to the handle was a little longer so used the old rod works perfect.From what I understand the plug didnt change untill the bf which u will need the wiring patch harness to hook up to earlier models.
08-05-2012, 12:01 PM | #7 | |||
Former BTIKD
http://stores.ebay.com.au/STRUT-ACTU...=p4634.c0.m322
08-05-2012, 12:33 PM | #8 | ||
I have used series 2 in a series 1 before and then when you lock the car all the locks do a routine if lock unlock lock every time you lock it or open it. Ended up swapping the broken gear in the lock from the series 2 into the series 1 lock pug it back in and it was good as new.
Toy Car Build |
08-05-2012, 01:07 PM | #9 | ||
Pro Street Au Ute
I seem to recall when doing mine that its a b series that i got for my au1.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
08-05-2012, 08:16 PM | #10 | ||
My friend got his series 1 au actuator replaced with a ba/bf type and on locking unlocking it's locks 3 times up down could this be why? Longer ba rod or something?
08-05-2012, 08:38 PM | #11 | |||
08-05-2012, 09:39 PM | #12 | |||
Told them what the vehicle was and its in the mail already. Funnily enough, after putting the purchase off for a few days and then deciding to go ahead with it, i went out the next morning and the dorr lock works fine again - typical. Ill replace it anyway along with all the locks and ignition barrel - all are either worn or dodgy. |
09-05-2012, 10:55 AM | #13 | ||
They are different, as others have said.
I used the (larger) cog and slider from a passenger side AU2 lock to replace the broken (smaller) cog in my AU1 drivers side lock. Make sure you grease the cog very well. |
30-04-2023, 02:54 PM | #14 | ||
Just to dig up this thread and not make a new one are BA Falcon Ute door actuators different from the sedan fronts?
30-04-2023, 06:23 PM | #15 | ||
Regular...with metamusal
03-05-2023, 04:00 PM | #16 | ||
Next upgraded Mk1 Leopard
I did a quick search on eBay and Au, Ba and Bf come up the same.
21-05-2023, 01:38 AM | #17 | ||
