Thailand Specials
I've got a bit of an odd question here, is it possible to modify an injector to increase the amount of fuel that can flow through it without buying new ones?
If it can be done, I can't imagine they'd last too long if they're stock.
It would be easier just buying a new set |
I ♥ EDM
![]() Join Date: Aug 2006
Cheaper & easier to get new ones.
#4 | |||
Thailand Specials
#5 | |||
I did one, but the people who've modified them found nothing but flow problems due to them all not being exactly the same (Backyard modding) |
Resident F1 Troll
you can get them drilled out bigger best done by someone who knows what theyre doing you'd want to get them flow tested and matched afterwards as you have no idea what they can do when you go to tune them
Injector orifices are the most precision made part of the vehicle. I would not get them drilled out.
If you want increased flow rate from the same hole size, increase the pressure difference across the hole. i.e, Increase your fuel pressure. This may not be ideal as the injector orifices are designed with a particular pressure in mind to give a particular spray pattern but later multi-hole injectors are much more tolerant of pressure variation than older single pintle styles. |
#8 | |||
Thailand Specials
What the plan was is that increase the duration of the injectors but it gives less time for the fuel to burn, so we're going to get lots of smoke at high revs/full throttle. |
#9 | |||
I am Batman
So you want the car to run rich...? Or have I missed summat? |
#10 | |||
Thailand Specials
As far as im aware about the only way to get anymore fuel is to change either the fuel pressure or the duration of injectors. I assume your talking about your focus?
#12 | ||
Drill a hole just after the throttle body and mount an auxiliary injector if you want to dump more fuel in, you can control it with a variety of aftermarket piggy back injectors, such as a PerfectPower SMT6.
Lol!.
#14 | |||
Wouldn't touch orifice size, as this may affect durability. Opening time is tune change Fuel pressure multiplies the delivered fuel by the percentage of pressure increase. Just a thought |
#15 | ||||
Thailand Specials
![]() A few others have tried changing the duration to a longer time, they get the desired effect but then they start belching out black smoke under hard acceleration because it can't burn all the extra fuel in time and it just goes out the exhaust. With fuel pressure, you can only go slighty higher than factory before a sensor goes out of range. Quote:
#16 | |||
Diesels will always blow black smoke when you add fuel because they don't have the opportunity to vaporise it as well as a petrol does. |
