Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 23-06-2011, 03:03 PM   #1
xt falcon
Default price for brembos
hi.
i have an fg xr6t ute and would like a price on a set of 6/4 with everything to bolt up. also can you do these as silver caliper red writing.
thanks
Aaron
xt falcon is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 06:32 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: price for brembos
Originally Posted by xt falcon
hi.
thanks
Aaron
Aaron we can supply all this for $4500 but we do like to worn people that with brembo's on the rear you get pad knock off as there will be bearing movement in the rear end. We can supply the 6 piston 355mm front brembo kit with the pbr 1 piston 328mm rear for $3500. The calipers are only red with white writing sorry.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 23-06-2011, 11:41 PM   #3
[THOMMO]
[THOMMO]'s Avatar
whats this pad knock off ?
[THOMMO] is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2011, 12:20 AM   #4
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
Quoted from here
When you use the brakes, hydraulic pressure obviously pushes the brake pads against the discs. When the pedal is released, the seals retract the pads just the right amount to prevent a spongy pedal without dragging on the discs and reducing the effect of your beautifully built engine.
When pad knockoff occurs several things can happen:
1)The wheel bearing/hub assembly distorts causing the disc to run non-parallel to the caliper, thus pushing back the pads. This happens in the stress of competition as you charge through the forest.
2)Freeplay in the wheel bearing causes the disc to wobble and knock back the pads.
3)Severe vibration can cause the caliper pistons to "walk" back into the caliper housing.
4)Other forces that a mere engine builder has no idea about.
How to solve the problem.
1)Fix the stub axle, hub, wheel bearing distortion at its source by fitting bigger components within the rules of course.
2)Adjust the wheel bearing you slacker.
3)Fit an anti knock-off valve. This valve fitted in the brake line supplies a small residual pressure to just hold the pads against the rotors. It has the down side of supplying slight drag which reduces the effect of your beautifullly built engine but if the engine is any good you will hose the opposition anyway. (It can't be your driving that is the cause of your poor results can it M? It must be someone else's fault.)
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 10:19 AM   #5
xt falcon
thanks for that i was unawear of the pad knock off on the rear end. i really don't want red calipers so is there anything else i should maybe look at?
thanks
Aaron
Old 26-06-2011, 10:46 AM   #6
Black F6
Black F6's Avatar
Some paint
12.33@112mph (stock)
11.00@125mph 98 (387rwkw) (CMS)
10.19@139mph (450rwkw) (Nizpro)(SOLD)
10.25@138mph FG XR6T (new toy) (Nizpro)
Black F6 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2011, 10:40 AM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
thanks
Aaron
You could repaint or have someone repaint the front Brembo calipers as you won't find anything else with the same quality like the 6 piston 355mm front brembo kit and the pbr 1 piston 328mm rear for $3500.
AP Racing calipers are black with yellow writing and ALcon are silver with blue writing but a front kit with a similar size to the brembo is close to $5000 for the front alone.
MATTHEW PEARCE
Phone 02 9609 1101
Old 28-06-2011, 01:50 AM   #8
z80
You could have alook at this lot?
They have 8 piston as well.
z80 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2011, 08:19 AM   #9
05_ENFORCER
05_ENFORCER's Avatar
The OP wanted silver calipers.
The ones you refer to are orange.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2011, 09:29 AM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I deleted the link as these products are inferior to what we sell and are not recommended by us. The products should not be promoted in our sponsored forum sorry without our consent.
MATTHEW PEARCE
Phone 02 9609 1101
