Old 22-03-2011, 05:53 PM   #1
baz
Default Site for cougar parts
I just found this site in the USA, www.car-stuff.com, they sell A/C compressors cheap but you would have to have a friend in the US they can post to as they don't do international post at the moment.
Baz
baz is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2011, 02:26 PM   #2
thearrow
Default Re: Site for cougar parts
I have a distinctive "clicking" noise in my front end that only occurs when I am turning to the right. I have already replaced my front driveshafts so it is not that.
It is not wheel bearings as it is a different sound all together.
Any idease anybody???
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2011, 03:42 PM   #3
baz
Check your power stearing, could be low on fluid
Old 23-03-2011, 03:56 PM   #4
baz
Also check your steering rack bolts, remove bolts, grease where the rack meets the frame and do up tight.
Old 23-03-2011, 05:59 PM   #5
thearrow
It's not power steering fluid, I have had this before when I had to replace the pump. I will have the bolts checked next week.
Old 23-03-2011, 07:26 PM   #6
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
CV Joint mate.
Old 24-03-2011, 03:47 PM   #7
REDDYZ
REDDYZ's Avatar
Try turning right while accelerating (just a bit hard) and try the same without acceleration with foot on clutch (if automatic shift to neutral). See if there is any difference. If it makes noise only in the first instance (while accelerating) then it is most likely diff in the gearbox. And can you feel the clicking feedback on the steering or its just the sound? I had similar problem with my Toyota corolla and tried replacing all possibilities and now replacing gear box with second hand one. It could be cv joint in power steering rack too. But its rare to happen. Also its worth getting checked newly replaced drive shafts, you never know when things break down.
Yogi
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
