Old 13-01-2011, 02:44 AM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Capri Front Lights
Hi All
i have a mk.1. capri pre/facelift 1972 .i would like to install the mk.3. front round lights on as i think the round lights look the goods
has anyone installed them do they need modify big time or just a small amount ..
just trying to give the car a meanner look on the front
cheers
gerry
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2011, 04:33 PM   #2
Jim5_0
I'm doing that to my Capri but using MK1 Facelift headlights.
To do it properly you need the headlights and all associated fittings but the Facelift had welded in metal buckets behind the headlights not the plastic ones that we all know and love.
You could possibly get away with using the existing plastic buckets but they are smaller than the facelift ones.
You would also need a Facelift bonnet or else the inner headlights become shrouded by the bonnet.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2011, 09:40 PM   #3
allanv6gt
Tippy-tronic Free Zone
And....I'm told (not verified by myself) the facelift also required some rejigging of the engine bay side skirts for the wider space taken by the headlight buckets.
Plus that different bonnet as Jim has mentioned - fibreglass versions readily available.
Alternately, fit some rectangular driving lights into your grille. I did just that and it looks much more business like.
Old 30-01-2011, 02:41 AM   #4
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
hi all
i think ill just keep it all standerd ..it will still look the goods ......
Old 30-01-2011, 10:14 AM   #5
u2canb12
u2canb12's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising cruises and keeping the events in the spirit of the forums
Smile
Originally Posted by WOGBOY69
hi all
Hey Gerry, I still reckon it will be tuff with the standard headlights, sounded like a lot of work to change. Just think, it means you will be cruising earlier......
Garry
u2canb12 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2011, 10:29 PM   #6
Jim5_0
Correct. The Facelift buckets that I have incorporate some of the inner skirt so I'll have to find a way to join them neatly.
