Old 15-10-2010, 09:34 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default Flushing brakes how much will I need?
I'm putting high temp brake fluid in I've got 1 lt will that be enough to do a full flush and have it full? Thanks.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 15-10-2010, 10:18 PM   #2
frd906
Just buy another bottle just in case, better to be safe and sorry
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2010, 10:21 PM   #3
Sizey
Mk5 Transbulance
!l should sure do it. However always have a spare 500ml bottle floating around. You never know when you may need it.
DOING THE UNDO-ABLE
B series xr6 wagon
Now deceased
BF Fairlane ex taxi
Now for more fun
[/CENTER]
Sizey is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2010, 10:25 PM   #4
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
Changed the fluid in my BA to AP dot6 had some left out of a litre when I did mine.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2010, 10:34 PM   #5
Day-mow
rexnet
Day-mow's Avatar
Ohk. Thanks it's penrite sin brake fluid rated to 310 degrees. It's a synthetic do I need to do anything special?
Old 15-10-2010, 10:40 PM   #6
mik
mik's Avatar
i usually have some left out of 2 standard bottles.
Old 15-10-2010, 10:43 PM   #7
adrian k
adrian
adrian k's Avatar
just did ,ine two weeks ago, I put thru half an oldish bottle i had first to flush the old crap out, then 1 bottle to flush again and then 1 bottle to fill, but it was well over due hence the xtra attention.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2010, 12:35 AM   #8
Day-mow
rexnet
Day-mow's Avatar
I have a syringe to get rid of the old stuff so only pumping the crap in the lines out
Old 16-10-2010, 06:43 AM   #9
adrian k
adrian
adrian k's Avatar
don't forget all the crap that builds up in the calipers them selves, this is the worst as it gets all the heat and can damage the seals. when i stripped my calipers i could not believe the crap that came out.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 16-10-2010, 01:29 PM   #10
mik
mik's Avatar
yep this is why fluid is flushed periodiclly, every 12 months i think.
Old 16-10-2010, 06:19 PM   #11
adrian k
adrian
adrian k's Avatar
and i have never had any ford dealer or garage say it needs doing, amazing considering it could be a safety issue. but then again, my dad never did his in the 20 years he own one of his cars.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
