Old 30-05-2010, 05:09 PM   #1
Tom_Jane
Tom_Jane's Avatar
Default how long can engine oil be stored once the bottle's been opened?
read title.
Tom_Jane is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:13 PM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
4 ever...
Daily driver GTE FG..
Old 30-05-2010, 05:22 PM   #3
BOSHOG
avenge me
BOSHOG's Avatar
Originally Posted by ebxr8240
4 ever...
i wouldve thought it had a shelf life, are you sure about this?
FULL OF Autotech GOODNESS!
BOSHOG is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:26 PM   #4
irish2
Keep the bottle closed so no moisture can enter it and it will last years.
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:28 PM   #5
ebxr8240
ebxr8240's Avatar
Like a good red...
Old 30-05-2010, 05:33 PM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
That's good to hear as I have used some old stuff before, when I say old, I bought a 20ltr drum as it was cheaper and did all my own oil changes, and as I don't do many klm's a yr, it was a fair while till I used up the 20 ltr drum, I keep't it clean and in a cool enviroment.
Old 30-05-2010, 05:39 PM   #7
zdcol71
zdcol71
zdcol71's Avatar
Like a good red...
I would have thought that like "a good red", once it is open and subject to moisture, it may have a limited life in the bottle?
: 30 years later
zdcol71 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:43 PM   #8
LUXO_8
windsor user
if there were a shelf life, it would be on the bottle
Old 30-05-2010, 05:44 PM   #9
DJR-351
I am Groot
DJR-351's Avatar
Just to mix things up a bit....
Scroll to bottom of the page...
http://www.carbibles.com/engineoil_bible.html
Engine Oil Shelf Life.
I couldn't decide whether to put this in the FAQ or the main page, so it's in both, because I get asked this question a lot. Typically, the question is along the lines of "GenericAutoSuperStore are having a sale on WickedlySlippy Brand synthetic oil. If I buy it now, how long can I keep if before I use it?"
In general, liquid lubricants (ie. oils, not greases) will remain intact for a number of years. The main factor affecting the life of the oil is the storage condition for the products. Exposure to extreme temperature changes, and moisture will reduce the shelf life of the lubricants. ie. don't leave in the sun with the lid off. Best to keep them sealed and unopened.
Technically, engine oils have shelf lives of four to five years. However, as years pass, unused engine oils can become obsolete and fail to meet the technical requirements of current engines. The specs get updated regularly based on new scientific testing procedures and engine requirements. But this is only really a concern if you've bought a brand new car but have engine oil you bought for the previous car. An oil that is a number of years old might not be formulated to meet the requirements set for your newer engine.
If your unopened containers of engine oil are more than three years old, read the labels to make sure they meet the latest industry standards. If they do meet the current standards, you might want to take the extra precaution of obtaining oil analysis before using them. An oil analysis will check for key properties of the oil and ensure that it still meets the original manufacturing specs. Of course the cost of getting an analysis done on old oil is probably going to outweigh going and buying fresh stuff. So it's a double-edged sword.
As a general rule, the simpler the oil formulation, the longer the shelf life. The following is a guideline under protected conditions:
Product Shelf Life
Base Oils, Process Oils 3 years
Hydraulic Oils, Compressor Oils, General Purpose Lubricating Oils 2 years
Engine Oils and Transmission Oils 3 years
Industrial and Automotive Gear Oils 2 years
Metal Working and Cutting Oils 1 year
The following are signs of storage instability in a lubricant:
•Settling out of the additives as a gel or sticky liquid
•Floc or haze
•Precipitates/solid material
•Colour change or haziness
Water contamination in a lubricant can be detected by a "milky" appearance of the product.
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:45 PM   #10
BOSHOG
avenge me
BOSHOG's Avatar
years isnt forever.
would mineral oil and synthetic also have different shelf lives?
to the OP, i get my oil in bulk from my mate who works for FUCHS and he gets me 4x5l bottles instead of a single 20l drum purely so "it doesnt go off". theyre his words not mine
Old 30-05-2010, 05:51 PM   #11
Wardo
Wardo's Avatar
We have drums of oil sitting around for ages at work, I usually give them a shake and then decant onto a clean rag, if it looks clean, good to go!
Only mineral though, Hydraulic and synthetic get a much closer inspection.
'03 BA Futura, 18' -235/40, Kingsprings superlows, Monroe GT Sport, 2.5" Cat and exhaust, K & N, Typhoon CAI, RDA Slotted & Extreme pads.
302 Cleveland being rebuilt, Ebay said 351 liars!!!!! Home found! '01 AU II. Bring on the smoke
Wardo is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2010, 05:53 PM   #12
irish2
years isnt forever.
If your THAT concerned mate change your oil every 1000k's. Oil 1000k's old will be worse than oil stored properly for 3 years.
Old 30-05-2010, 05:57 PM   #13
BOSHOG
avenge me
BOSHOG's Avatar
are you sure? i mean if youre qualified to make the judgement ill do as im ordered!
FFS way to make a good thread into a bitchfest
Old 30-05-2010, 06:02 PM   #14
irish2
Every time your engine cools you get condensation on the inside of your crankcase. By heating and placing the oil under pressure you are shearing the friction modifiers within the oil, effectively changing the oils weighting over time. This would not happen to sealed oil.
Old 30-05-2010, 06:05 PM   #15
BOSHOG
avenge me
BOSHOG's Avatar
that makes total sense
i usually change my oil between 3000-5000km because it doesnt get driven much so i probably wont have issues with this
i have 2 unopened bottled of syn and 1 open (4 litres left) will these both "go off" in the same timeframe?
Old 30-05-2010, 06:21 PM   #16
pottery beige
stop thinking so much.. your head will hurt....
Old 30-05-2010, 06:23 PM   #17
JimNiki
71Mach1
JimNiki's Avatar
haudraulic lifters not so important
solids a bit more important
also crusing not so important
racing/redlining more important
all oils will lubricate
only the better ones will prevent serious damage if metal contacts metal under severe circumstances... Have we had the ZDDP discussion anywhere...?
roses are #FF0000
violets are #0000FF
all my base
are belong to you
JimNiki is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2010, 12:22 AM   #18
GK
Walking with God
GK's Avatar
I keep some older oil around the place (say 5 or more years) in sealed containers, in case I want to flush the diff or gearbox when I do a fluid change.
As for the cars though, I wouldn't really keep oil for longer than a few years. I do buy a number of containers when it's on special however! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 31-05-2010, 12:36 PM   #19
Mainlube
Mainlube's Avatar
This one I decided to bounce off the Chemists (even though I have my own opinion)
The text book says around 2 years (you know how I feel about text book worriers)
Guide lines as follows, you need to consider ......
As long as the OLD spec still protects your machine.
As long as the container was resealed after opening. (if left open to the air can oxidise)
Stored under cover (not in rain or sunlight) under 40C
The maximum I would (and the Chemist would) keep oil and still use .......
10 years
But the book says 2 years (they're hoping you'll buy more!)
Steve
MainLube - Extreme Lubricants For Overdriven Machinery
Mainlube 175 Synthetic Race Oil SAE 10w60 (engine)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff)
www.Mainlube.com.au
Mainlube is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2010, 01:03 PM   #20
LTDHO
The one and only
LTDHO's Avatar
years isnt forever.
Is 4x5 same price as 1x20?
Tuned by CVE Performance
Old 31-05-2010, 01:29 PM   #21
BOSHOG
avenge me
BOSHOG's Avatar
im pretty sure it is. i paid $180 for 4x5l FUCHS TITAN supersyn 5w40
Old 31-05-2010, 03:48 PM   #22
prydey
Rob
prydey's Avatar
while the oil i use is readily available, i see no reason to stock pile it. buying in bulk is sometimes cheaper but it can depend where you buy it from. i use shell helix ultra, which is upwards of $60 at most auto stores and sometimes over $70 for 5L. it is also available at BIG W for $40 - $50!! they obviously have much better buying power than your average auto store.
Old 31-05-2010, 07:47 PM   #23
Bossxr8
Peter Car
Bossxr8's Avatar
Depends how quickly you put it in the fridge after opening.
Old 31-05-2010, 08:17 PM   #24
JimNiki
71Mach1
JimNiki's Avatar
I've got 4 tins of full gloss and semi gloss por15 in our main fridge
been there for 2 years? keeps longer.
roses are #FF0000
violets are #0000FF
all my base
are belong to you
Old 31-05-2010, 08:21 PM   #25
Falc'man
You dig, we stick!
Falc'man's Avatar
10 years
Steve
Always appreciate the expert's opinion. Thanks.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
